Replacing Bonnet / hood insulation
ocde30
Post Thu Nov 21, 2019 3:53 pm
I fitted a new bonnet / hood insulation this summer - the old original insulation was crumbling and dropping off bit by bit with every bonnet close.
I know loads of you have already tackled this but hopefully these few pictures might possibly help or encourage anyone to do this fairly simple/worthwhile but potentially very messy job.
Like many of the other 30yr old E30 engine bays it looked like this before I started.
I never really considered removing the bonnet as my garage is very tight and didn't want to risk any accidental dents or paint scratches.
One of my concerns was stopping the dust and bits getting into the engine bay and creating further work.
I covered the engine bay ( wing to wing ) with cling film and then an old dust sheet on top of that. A bit of basic health and safety seemed sensible with so much dust.
Some of it came away easy but most of the remaining area needed the help of a scraper - used gently to avoid scratches to paint - no real force needed.
Once all the loose and flakey was removed I tackled a small area with a solvent to remove glue residue. After an hour of this on one small section I decided life was too short and resorted to rubbing any high spots off with a bit of sand paper.
The surface soon become smooth enough and stable enough to stick on the new replacement pieces of foam. These were self adhesive and the perfect fit. I looked at some on Ebay but decided to use Cotswold and get the genuine article.
It went on really easy but make sure you line it up carefully and start by removing backing in one corner only first ( obvious really ) because the adhesive is very strong and i don't think there is any possibility to " re position "
Worth it in the end though. After 9 months of extreme heat and cold there doesn't appear to be any difference where I stuck it onto the painted surface or onto the thin layer of old glue residue.
Makes all the difference to the appearance of the engine bay and hopefully is sorted for the next 30yrs!
ah
Post Thu Nov 21, 2019 8:46 pm
Been there done that.
boiliebasher
Post Thu Nov 21, 2019 10:14 pm
Great right up, thanks for sharing! :cool:
miniblob
Post Fri Nov 22, 2019 3:57 pm
Nice!
I will get that done, one day, eventually!!!
327 Touring with bass!!!
Post Fri Nov 22, 2019 4:42 pm
As above mate :clap: :clap: :clap: :clap:
Foe
Post Sat Nov 23, 2019 7:31 pm
Another thing on my list of to dos'
Nice work :thumb:
Moz
Post Tue Dec 03, 2019 9:49 am
A small job but makes a massive difference!
Great write up!
JGG1
Back in an E30 !
Post Thu Dec 05, 2019 10:08 pm
Great write up, convinced me to do mine. How much are the pads?
ocde30
Post Fri Dec 06, 2019 9:26 am
Hi, I think mine was about £47 from Cotswold.
JGG1
Back in an E30 !
Post Fri Dec 06, 2019 10:02 am
Thank you
minesapint
Post Thu May 14, 2020 12:53 am
A job I need to tackle soon, but don’t fancy the sanding technique.
I’m sure I read quite some time ago, a guy on here found a solvent which brought the old adhesive off easily, it was something like Toyota brake cleaning fluid. Can anyone confirm this?
coopman
Post Thu May 14, 2020 1:23 am
It's a job I'm planning too, so I've read a few recommendations. I've heard about brake cleaning fluid (not specifically Toyota), also lots of people suggest petrol. Surely white spirit would do the job?
Moz
Post Thu May 14, 2020 2:43 am
I used this:
https://www.ebay.co.uk/itm/311623978389
Spray on and then scrape off with a plastic scraper. It is still a pain to remove it all though so I've always removed the bulk then cleaned with IPA before applying the new insulation.
Ukhozi
Post Thu May 14, 2020 11:51 am
I am in the middle of doing one as I replaced the bonnet following the 'bit of a praang' I used the big workshop vacuum cleaner and sucked the crap off, removed any loose glue but as OP I just made sure the remaining stuff was solid, so now ready to fit new stuff once the underside is white.
Everyone has the right to reach the level of their own incompetence.
BenHar
Post Thu May 14, 2020 5:19 pm
Barry said Toyota brake cleaner does the job well.
Ben
JungleGus
Post Thu May 14, 2020 7:10 pm
I have found that a bit of spray adhesive may be needed as the stickiness of the new foam isn't 100%. May be less of an issue if you go to bare metal though.
Makes a big difference and nice to not have bits of 30 year old foam falling on you when working in the engine bay...
brutus
Post Thu May 14, 2020 9:16 pm
yep done it !
and all will say it makes a massive difference ! :D
ive a spare if any wanting ?
MANY e30 PARTS FOR SALE.
( all models available )
318i baur 1986 auto.
Ukhozi
Post Mon May 18, 2020 1:37 pm
I tried some 15mm foam that 'looked' the same from a friend who builds custom van interiors but it shrunk, went soft and fell off, so now I have an OEM set to fit after painting. Always use OEM.
kdevitt
Post Thu May 21, 2020 2:34 pm
I used the partworks one recently. To be honest I found it superior to the OEM one I previously used - doesn't have the square cutout, and stuck perfectly first time. The OEM one just never wanted to stay in place until I ended up using some stronger glue on it.
Moz
Post Thu May 21, 2020 2:50 pm
I've never used the parts work one but have had no issues with the OEM one. Maybe just a bad batch?
tha881
Post Thu May 21, 2020 4:48 pm
I used Oem foam, if you cant get the bonnet back to bare paint then it wont stick, especially the middle section. I used a bit of spray adhesive from screwfix and it done the trick
Cloggy Saint
Post Thu May 21, 2020 5:13 pm
I just removed the dry crumbling foam and couldn't be arsed to scrape all the old adhesive off. Ten years later it's still firmly attached.
kdevitt
Post Fri May 22, 2020 7:51 pm
Not sure - recently bought the Evo bonnet seals, and from reading online everyone said the adhesive was ultra strong. Same issue - barely stuck at all. Maybe they've switched to a weaker adhesive or something, back to metal and degreased both times.
Cloggy Saint
Post Fri May 22, 2020 10:04 pm
I had the same problem with my bonnet seals. I ended up using some 3M double sided tape in the end which worked ok, how did you deal with it?
kdevitt
Post Sat May 23, 2020 10:56 pm
I haven't fixed it yet - have some 3M bodytape as well which I planned on using, although I'm slightly concerned it will leave it sitting slightly off the wing.
Cloggy Saint
Post Sat May 23, 2020 11:35 pm
The stuff I used is extremely thin but strong and so far it's held, although even with bonnet catch adjustment it still pulls it away from the wing just a little bit. A good tip is don't cut the excess off at the front as the adhesive will be straining against the steep curve of the wing. Tuck it back between the grill and the wing.
