Oil in front strut
Foe
Post Tue Oct 01, 2019 10:03 pm
As I'm going to replace the steering rack, one weekend very soon, and after I complete a fuel pressure check, I might as well replace the front shocks. However does the strut need to be filled with oil on a 316i?
Post Wed Oct 02, 2019 10:31 am
I wouldn't say it's essential, but it's not going to hurt to add some, even if it's just to prevent rust.
HJ1981
Post Wed Oct 02, 2019 5:43 pm
Brianmoooore wrote: ↑
I was going to suggest light grease, but then decided not to, thought you guys would say i am a bit crazy.
Foe
Post Wed Oct 02, 2019 6:23 pm
Post Wed Oct 02, 2019 6:29 pm
Purpose of the oil is to help transfer the heat generated by the damper to the strut that surrounds it, so it can dissipate into the air.
Foe
Post Wed Oct 02, 2019 9:58 pm
Learning all the time :thumb:
Tzantushka
Post Thu Oct 03, 2019 11:32 am
Interesting to note, that if you're fitting gas struts - then the recommendation is not to add oil into the strut housing.
Seems odd - but I followed the bentley manual and added no oil when fitting the Bilsteins
Post Thu Oct 03, 2019 1:43 pm
Tzantushka wrote: ↑
If you mean inverted strut inserts, then the part where the heat is generated is outside of the strut tube anyway.
