e30 windscreen washers blocked
ronaldinho
Mon Feb 13, 2006 10:38 pm
hi, when i use the windscreen washers, water comes out only from the right hand side, the left hand side is blocked, any idea how to fix this?
Ziggy
Mon Feb 13, 2006 10:51 pm
Needle / pin in the hole! :thumb:
If that doesn't work, check the pipe's properly connected to the jet & it's not pi$$ing water out of a valve or anything...
