hey all, ive got an m40 with a leaking oil filter housing, its the metal type that uses one o-ring and i was thinking while ive got it off is it worth changing to the later e36/46 filter housing? they seem to be the same but the later one uses plastic bit with two o-rings instead.
not really sure if its an upgrade or downgrade but since ill be replacing all the o-rings, that plastic round bit (#4) and the gasket anyway an extra $8 for the later housing from a junkyard it could be worth it?
e30:
e46:
just looking for any opinions/experience with both designs
also not sure if this is the correct place to be posting it... any help would be appreciated
thanks!
m40 oil filter housing options
Rafael
if it bolts up and gives good oil pressure go for it .
+ a yard full of scrap turds
I have had three out of my three e46 cars needed to change the oil filter housing gasket but that was after 80k or so , no big job either.
