using RealOEM help
ronveerlal
Tue Apr 16, 2019 12:17 pm
Hi im looking for to replace my speedo sensor which is located on the rear diff I can't seem to find it on real oem can anyone help
thanks
http://www.realoem.com/bmw/enUS/partgrp ... BMW-316i/b]
jmc330i
Tue Apr 16, 2019 12:52 pm
How come you want to replace the sensor?
James
'91 325i Sport
'93 318i touring 16v
ronveerlal
Tue Apr 16, 2019 12:56 pm
speedo isn't working
jmc330i
Tue Apr 16, 2019 1:10 pm
Are you sure its the sensor? They rarely give issues, it's more likely the wiring from the plug. Brianmooore will give a better explanation, but the copper in the wire hardens over time and starts to breakdown.
The usual fix is to the replace a length of the wire (20-30cm or so) from the plug. An E30 headlight plug and wiring can be used and is likely in better condition as it hasn't spent a 25+ years under the car lol
Another issue can be a dry joint on the back of the cluster, if the odometer still works when the Speedo doesn't, it's likely this is the problem.
James
'91 325i Sport
Cloggy Saint
Tue Apr 16, 2019 1:23 pm
Here's the link for the sensor http://www.realoem.com/bmw/enUS/showpar ... Id=33_0121 but as jmc says it's far more likely to be a break in the wiring from the sensor.
ronveerlal
Tue Apr 16, 2019 5:52 pm
What number is it
BenHar
Tue Apr 16, 2019 7:11 pm
08 Pulse generator, speedometer
BenHar
Tue Apr 16, 2019 7:13 pm
Have you tested the wires at the sensor?
Have you taken any notice of the advice you've been given here?
Ben
