Is the Oil Pressure Sending Unit on an ix model unique?
StoneCold
Post Sun Feb 12, 2006 3:34 am
The "last" thing on the mechanic's to-do list to get my "new" 1988 ix (w/217,000mi) back home is to change out the oil pressure sending unit. The whole underside of the motor was covered in oil. I powerwashed it, ran the motor for @15 minutes and shut it down. When the oil settled back into the pan, the sending unit was where the oil was seeping from.
Is this sending unit particular to the ix due to the ix's oil pan, or is it a stock part from any 2.5L? Also, is there a special socket needed to get it out? Thanks everyone. If it is a stock part, I think I'll be able to get her back home by the middle of this week.
Regards,
StoneCold
Widge
Post Sun Feb 12, 2006 10:36 am
Is it in the drivers side of the block? which is where it is on "normal" M20's. OR is it in the sump?
Post Sun Feb 12, 2006 10:43 am
If it's the oil pressure switch we're talking about, rather than the oil level sender, then I'd be very surprised if it's any different from any other.
The oil pressure switch from most cars, full stop, will fit, not just BMWs.
StoneCold
Post Mon Feb 13, 2006 5:01 am
Oil pressure switch. The unit is on the block.
Another forum answered that the part on the ix is the same as on the i motors. I just wanted to make sure.
It seems that everything that needs replacing on the ix is specific to that model only (rotors, pads, shocks, struts, etc.)
Widge
Post Mon Feb 13, 2006 5:04 am
I would have thought that alot of it would be interchangeable. It would be difficult to tell though if the parts are the same and BMW just lists them with different part numbers. I have always fancied an IX but if the things so simple as brakes are different I don't think I would bother. No wonder they didn't make many if the drive train was basically totally different, seems like an expensive exercise.
jaistanley
Post Mon Feb 13, 2006 1:15 pm
The front struts towers look completely different..
Imagine your E30 was....gulp....front wheel drive. Thats what they'd look like 8O
Jai
Widge
Post Mon Feb 13, 2006 2:02 pm
Yeah ....obviously, but that doesn't mean that normal e30 rotors couldn't fit if BMW had wanted to make them fit.
