Looking on Ebay as you do I noticed an ad seller with a number of brand new injectors for sale
https://www.ebay.co.uk/itm/4x-AUDI-BMW- ... rk:12:pf:0
and part of the ad description is as follows :
SET OF 4x GENUINE BOSCH GERMANY 247cc EV1 FITMENT HI FLOW PERFORMANCE FUEL INJECTORS FOR TUNING / UPGRADE APPLICATION.
IDEAL FOR N/A & TURBO CHARGED L4 ENGINES.
PART NUMBER: 0280150728 BLUE TOP.
INJECTOR BODY: METAL & COMPOSITE PLASTIC WITH FACTORY FITTED UPPER AND LOWER O-RING SEALS.
DESIGN: BOSCH EV1
STATIC FLOW RATE: 24LB/HR @ 43.5PSI OR 248CC/MIN @ 3.0 BAR
ELECTRICAL CONNECTOR: EV1 2 PIN.
LENGTH: 3 inches, 74 mm
DIAMETER: 24 mm
O RINGS: Top and bottom, 14.5 mm
RESISTANCE: 14.5 Ohms/HIGH IMPEDANCE
FILTER DESIGN: BASKET FILTER AT INLET
I'm wondering whether they would be suitable for an m20 ? The bar pressure looks correct but that's as far as my technical knowledge extends to
325i injectors
reggid
they flow 60% more than stock to so without ECU changes its not going to work well...
E30 325is with M20B31
Bonymaenjack
steve_k
sorry but they are way to big for a standard m20,
steve_k
if you don't ask you don't find out.Bonymaenjack wrote: ↑Mon Jan 07, 2019 11:20 amThat's fine at least I've learned a bit more of what I don't know![]()
reggid
the right chip would work but it'd be a custom job. IMO no worth it. get some closer to stock (around 15lb./hr)
HJ1981
Go with the standard Bosch ones, or get yours serviced properly by a Bosch dealer.
It is a bit pricey, but they will flow test them and check them thoroughly (resistance, response etc).
Best price for Bosch ones that come with new seals i found is €65 each, i am still undecided if i should get mine services or get brand new ones that would last 10+ years (of course as with anything electrical and new, there is always a change of manufacturing defect, just stating theoretically they should last xxx years more).
Bonymaenjack
The set I currently have fitted were a spare set I had ultra sonically cleaned and refurbished with new seals and caps etc. but I suspect that maybe two are leaking ( yet to be confirmed as I have other fuel delivery problems which need addressing first ) I just saw them advertised and wondered whether they would fit . because that would have been a cheap deal for Bosch , when you consider I paid in 2016 £59 for a brand new Bosch fuel pressure regulator now retails at £200 .HJ1981 wrote: ↑Sat Jan 12, 2019 6:50 pmGo with the standard Bosch ones, or get yours serviced properly by a Bosch dealer.
milescook
Hi, I saw your other thread you mentioned you thought they may be leaking... one thing I'd say is you may have too many assumptions on the goBonymaenjack wrote: ↑Sun Jan 13, 2019 6:36 pmThe set I currently have fitted were a spare set I had ultra sonically cleaned and refurbished with new seals and caps etc. but I suspect that maybe two are leaking ( yet to be confirmed as I have other fuel delivery problems which need addressing first ) I just saw them advertised and wondered whether they would fit . because that would have been a cheap deal for Bosch , when you consider I paid in 2016 £59 for a brand new Bosch fuel pressure regulator now retails at £200 .HJ1981 wrote: ↑Sat Jan 12, 2019 6:50 pmGo with the standard Bosch ones, or get yours serviced properly by a Bosch dealer.
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
Bonymaenjack
I know my leading post did say that there seems to be a few issues which appear to overlap, so you can guess I'm a bit frustrated atmmilescook wrote: ↑Tue Jan 15, 2019 9:09 amHi, I saw your other thread you mentioned you thought they may be leaking... one thing I'd say is you may have too many assumptions on the goBonymaenjack wrote: ↑Sun Jan 13, 2019 6:36 pmThe set I currently have fitted were a spare set I had ultra sonically cleaned and refurbished with new seals and caps etc. but I suspect that maybe two are leaking ( yet to be confirmed as I have other fuel delivery problems which need addressing first ) I just saw them advertised and wondered whether they would fit . because that would have been a cheap deal for Bosch , when you consider I paid in 2016 £59 for a brand new Bosch fuel pressure regulator now retails at £200 .HJ1981 wrote: ↑Sat Jan 12, 2019 6:50 pmGo with the standard Bosch ones, or get yours serviced properly by a Bosch dealer.
Best price for Bosch ones that come with new seals i found is €65 each, i am still undecided if i should get mine services or get brand new ones that would last 10+ years (of course as with anything electrical and new, there is always a change of manufacturing defect, just stating theoretically they should last xxx years more).Who did the injectors for you? Injectortune did mine I've never heard any problems if it's them.
Easy to check for leaking injectors with a pressure gauge. Pressure should be maintained for many hours after stopping the engine, especially if the supply and return hoses are clamped off. Only way for the pressure to drop then is via the injectors.
