OBC screen replacement
senna
I have the basic OBC (? 6 buttons can't remember)
The screen has bleed.
Does anybody replace these?
The screen is easy enough to change, but, AFAIK, there is no source of replacement screens, other than an E30 OBC with other problems.
senna
Well, as per senna's link, it seems that an enterprising young man in Germany has indeed started producing replacement screens, after needing to source a screen for the clock in his Porshe 944!
https://www.partworks.de/gearworks-de/D ... hparam=e30
Cloggy Saint
+ a yard full of scrap turds
looks like i worked out how to buy a 13 button one
He lists the gears for E30 odometers as well.
Gert_8
Steve
I've bought one from them, it arrived very quickly, but I wont be fitting it anytime soon, too busy at the moment.
webmaster@e30zone.net
Gert_8
let us know how you get on, Steve. It's a good price and if it does the job, it's much better than replacing the whole OBC unit. I like the idea of keeping the original one and being able to replace the screen.
Steve
It will be a result if it works, I will post some photos up later of what I recevied.
aimlessrock
interested in this also. mine has bleed over the summer!
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
steve_k
i'll be watching this as the screen on my OBC has bled as well, keen to see if it works.
also, anyone know how to replace the screen on a 12/13 button OBC?
Gert_8
it's the 13 button one I would be interested in too. I'm guessing the exchange process will be the same for both..
Topblag
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
corkie
im sure a guy called luke yeti o neil on the zone fb page has bought these and they work as they should.
e30
Gert_8
davidt
- Pompey Council 4 door deviant
This link explains how to do it. https://www.r3vlimited.com/board/showth ... p?t=418494
M3KUK
They work, I bought one.
Gert_8
Thanks Davidt!davidt wrote: ↑Fri Dec 07, 2018 6:42 pmThis link explains how to do it. https://www.r3vlimited.com/board/showth ... p?t=418494![]()
Steve
Sorry, I forgot about the photos, here’s everything I received.
Gert_8
Thanks Steve. Let us know how you get on with this please. The instructions seem fairly clear.
you've got a 320i, it takes all kinds!
Topblag
That's a bit harsh, the sump from a 320i is worth keeping....
Gert_8
Got one as a Christmas present. Need to make time to fit it now...
kdevitt
Got one of these during the week. All fitted up fine - clipped the back of the OBC back on and the screen went down in a blaze of glory. Compared it to the original, and its significantly thinner - so its a good bit more fragile. Pretty irritating to have to fork out for a new one again.
Gert_8
What do we need to know to avoid your mistake?
kdevitt
Really don't know to be honest - have had the OBC's apart a good few times without issue. The LCD casing from my OBC was different to the one in the instructions - my good OBC doesn't have a ribbon connector, I had another unit with the ribbon connector - see below, not sure if that caused a problem. The website says its not suitable for US OBC's for some reason.
The casing wasn't overly tightened when being screwed down. Clipping the backpiece of the OBC back on shouldn't have caused any problems, but there was an audible cracking noise when it went. Potentially the LCD hadn't sat into place correctly or something.
