V12 meets E30 Touring
Kos
Mon Jan 23, 2006 7:47 pm
Argos wrote:The M70 V12 is a cracking old motor. Not very heavy either - it weighs 529 lbs with the air con pump (495 lbs without) compared to 465 lbs for an M30 3.5 0r 390 lbs for a 325i lump.
It would be daft not to change the sump gasket with the engiune out as it will be impossible to do when it's fitted, and V12 sump gaskets do like to fail. You'd probably get away with an E28 535i rad to start with The V12 isn't that big (no longer than an M20) and because it's a narrow angle V, not particularly wide either.
Bollocks to 6 speeds - I'd be sticking with the 4 speed switchable Auto! Stick it in D at the lights and just floor it. 0-100 in about 13 secs, no lifting off, no gearchanging. Sweet.
with nos!!!
www.pukardesigns.com
IG Pukar.Designs
glenn
Engine Transplant Services
Wed Jan 25, 2006 6:55 pm
little update
started stripping the engine bay this evening.
radiator, air flow meters and filters, header tank and climate control motors. i'll probably go for a lift at the weekend when i have more light.
maxfield
Wed Jan 25, 2006 6:57 pm
Cant wait to see it finished
ZS
Thu Jan 26, 2006 11:45 am
Love the Stilson on the V12. Real driveway mechanicing. ;)
Once driven, forever smitten.
Direct injection, turboed, intercooled, 16 valves giving a whopping 48.5hp/litre!! :(
Widge
Thu Jan 26, 2006 5:13 pm
I was gonna say, I hope you haven't been touching that beautiful BM V12 with that grotty little stiltsen!! And I hope you aren't using ajustable spanners on this job :wink:
glenn
Thu Jan 26, 2006 7:09 pm
the biggest open ended spanner i have is 22mm, and it's not big enough for the oil cooler take off pipes. the biggest socket i've got is 64mm, inch drive. perhaps if i'd looked at it long enough with my uri gellar expression it may have undone itself.
i dont own an adjustable!
WerkdE30
Sun Jan 29, 2006 10:28 am
This is one of the greatest things i have ever seen good luck!
Cant wait to see how it goes...
glenn
Sun Jan 29, 2006 9:30 pm
got the m70 out this weekend, with its autobox.
autobox is off now, got to get a spigot bearing this week so i can trial fit the manual box to the block.
got to get ourselves familiarized with the wiring on the engine first so we can strip the engine wiring down a bit.
there's about 120 wires going to 3 ecu's at the moment
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Sun Jan 29, 2006 10:49 pm
this is soooooo cool :)
M3power
Sun Jan 29, 2006 11:00 pm
Mighty Glenn,
Good luck with this project! I know how much space there is to put a V12 into an E30.
You must have got some huge steel balls to do these cars... :mad:
Clear style, 18" , e39 M5 block and all Ground Zero sound is going to make my Dutch e30 Pound!!!
glenn
Mon Jan 30, 2006 6:59 pm
removed the dual fuel pumps out of the e32 tonight and removed the throttle potentionmeter(sp?) (fly-by-wire-throttle).
we've established which multi-plug is for the throttle and the fuel pumps.
all the wires we need are being loaded onto the computer for future reference in case anyone else wants a V12 conversion done!
glenn
Sun Feb 05, 2006 1:21 pm
engine is lowered into the bay, it's not the finished position, it's going to be dropped a further 12mm.
just took a few pics for your enjoyment!
Dan318-is
Sun Feb 05, 2006 1:22 pm
You dont hang around do you!
DieselMeister
Sun Feb 05, 2006 4:00 pm
Nice.
glenn
Sun Feb 05, 2006 7:11 pm
this will now be the finished engine position.
bigkev
Sun Feb 05, 2006 7:15 pm
looks like it was made to measure :D
Ant
Retired Team Member
Retired Team Member
Sun Feb 05, 2006 7:19 pm
V tidy !
Lovin this BTW, howz the steering clearance looking Glenn ?
bigun
Sun Feb 05, 2006 7:20 pm
glenn wrote:this will now be the finished engine position.
that looks quality in there :clap:
glenn
Sun Feb 05, 2006 7:33 pm
ant wrote:V tidy !
steering clearance is not going to be a problem ant,
each bank of cylinders has two manifolds, covering three ports each,
just need to source/swap one of the manifolds over to the other bank as their outlets are on the end's of the manifolds and then there's more room than the S62 steering.
i'll take a pic of the steering clearance next week ant, a picture explains it easier :?
DieselMeister
Sun Feb 05, 2006 9:06 pm
What about the brake servo, or is that not an issue here?
glenn
Sun Feb 05, 2006 10:07 pm
DieselMeister wrote:What about the brake servo, or is that not an issue here?
we're gonna use the E32 hydraulic booster/master cylinder.
tylerma
Sun Feb 05, 2006 10:14 pm
Glenn I hold my hat off to you dude
for taking on such a project,
and I hold my hat off to Dips
for wanting such a beast.
you are both legends :)
I shall be watching this thread
I wanna see this baby grow.
BTW Glenn
I have aquired a harrier jump jet engine
how much you charge to fit that mate
fuzzy
He who sleeps with "Gingers"
Mon Feb 06, 2006 9:48 pm
that certainly is a tight fit with not much room to work in, but looking good so far.was there any modification needed to the chassis/crossmember? mine needed some chopping of the front chassis legs ,and thats only a 4 pot! id like to see this one when finished some day.any idea of when you expect to be finished? :cool:
wally
Mon Feb 06, 2006 9:52 pm
just keepin an eye on mad max 8O
JoeP
Location: The Bunge, Waveney Valley, Norfolk/Suffolk border
Tue Feb 07, 2006 6:09 pm
Glenn you're an utter legend, that is truly inspirational.
Alpine White 325i touring
Saying 'No' to saloon and cabriolet wrongness :-)
mason
Fri Feb 10, 2006 9:45 pm
tylerma wrote:Glenn I hold my hat off to you dude
BTW Glenn
Have to agree with above credit to Dips your mad mate
Glenn your amazing keep up the good work
Mason
andymatthew
Sun Feb 12, 2006 8:40 pm
:eek:
Martinaston
Sun Feb 12, 2006 8:55 pm
Looks like it's a monster, i dread to think what the insurance quote will be :eek:
I'm interested to know how you'll run the exhaust('s) :?
There is NO nucleus.
Toby_Unna
Boost Junkie
Mon Feb 13, 2006 2:37 am
Martinaston wrote:Looks like it's a monster, i dread to think what the insurance quote will be :eek:
well that's an exciting way to look at it :?
it's common to insure at the same level as the donor car, so not cheap but not silly.
looking as good as you'd hope Glenn :cool:
glenn
Thu Feb 16, 2006 9:24 pm
little update,
had the cars here a month now, the way things are going it should be done ahead of schedule.
managed to keep all four manifolds in their existing positions, downpipes are finished. they had to be altered to miss the steering, the gearbox, the rear control arm mountings and the floor of the e30!
engine mountings are finished, just need to be painted.
was going to use an extra large e30 radiator that dips supplied but the top outlet was up against the nearside distributor, so we're now using the e32 radiator, so the front chassis legs have had to be modified to accommodate
it.
so that the hydraulic brake booster can fit, we're moving the hole for the servo about 2" to the nearside, so that it fits between the nearside suspension turret and the offside cylinders intake manifold.
also to be modified, is the bracket that supports the servo, and the bar that links the pedal to the servo.
gareth
Thu Feb 16, 2006 9:48 pm
sounds like you're having a whale of a time!
will a E28 535 rad not work? i looked at using the E32 735i rad on my M30 conversion (as it was mint and free) but it was too wide to fit between the chassis rails, the E28 one is the same except the right hand tank is cut out to avoid the chassis rail, with the bottom hose outlet above the chassis rail (e32 one would be below it).
or does the V12 one need a vastly larger rad?
dips346
London Meets Main Man
Thu Feb 16, 2006 10:34 pm
the v12 rad is huge mate
gareth
Thu Feb 16, 2006 10:40 pm
who's hugh? :D :mrgreen:
oh well...
i've heard ages ago about someone contacting a forklift truck manufacturer for a rad as they use small very high efficiency radiators as they don't get much airflow due to speed!
iirc they'll work out about half the size.
dips346
Thu Feb 16, 2006 10:49 pm
oops :oops:
Kos
Thu Feb 16, 2006 10:51 pm
number sent
IG Pukar.Designs
