Anytime you need it bud its's there for you .Sanchez wrote:Colour match on the leather is good. Jealous of the unit.........
My 325 touring project
shedrool83
shedrool83
Finally got round to doing a job i have been avoiding for a while now.
The manual sunroof didn't want to open and there was signs of rust on the panel.
Eventually got it opened enough to remove the panel to find what i already knew.
After i got the panel out i can now see why it didn't want to open (apart from the rust that is).
The guides either side seen to be out of sync.(anyone know how to sort this ?)Also how do you remove the sunroof headlining panel ? (the wee metal arms)
Next was the head lining to come out and clean off the old crap ready to retrim. Also put inners and outer tie rods on the newly purchased purple tag.
- Brianmoooore
Sync. by removing the motor and gearbox assembly, manually pull each side of the mech. to full tilt (I think there's a couple of holes for pins each side that line up when this is achieved, but I've never used them), connect the electrics back to the motor, use the switch to set the motor to full tilt, and refit.shedrool83 wrote: The guides either side seen to be out of sync.(anyone know how to sort this ?)Also how do you remove the sunroof headlining panel ? (the wee metal arms)
More importantly, how did it get out of sync in the first place? Hopefully no damaged gearbox cogs.
IIRC, the small metal arms just pull off. It's definitely not difficult, or I would remember.
shedrool83
It's does look like the arms just pull off put they weren't coming easy so thought i'd check rather than break anything.Brianmoooore wrote:Sync. by removing the motor and gearbox assembly, manually pull each side of the mech. to full tilt (I think there's a couple of holes for pins each side that line up when this is achieved, but I've never used them), connect the electrics back to the motor, use the switch to set the motor to full tilt, and refit.shedrool83 wrote: The guides either side seen to be out of sync.(anyone know how to sort this ?)Also how do you remove the sunroof headlining panel ? (the wee metal arms)
Its a manual sunroof and the handle was slipping now and again when i tried to get it open.
- Brianmoooore
Well, that explains how it got out of sync. Hopefully, no damage gas been done to cables or gears.shedrool83 wrote: Its a manual sunroof and the handle was slipping now and again when i tried to get it open.
Be very careful of the large stainless steel plates when you dismantle the mechanism for cleaning and lubrication - the edges are razor sharp.
Pull the cables out of the tubes, clean off all the old grease and apply new.
Synchronising the cables is much the same with a manual roof as with an electric. Just set the manual winder to full tilt before refitting it.
shedrool83
shedrool83
shedrool83
Glad i stuck this up in the garage roofs many moons ago .Not 100% rust free but very little.
Fitted
I am so glad to see that we are still doing "proper" things to our cars !!!
I have most bits for mine , and when it`s not around freezing, then I will attack it in the same way and attitude you have
shedrool83
Can’t get near this atm due to prepping an e46 for a banger rally ,but did manage to pick up new wheels.
Complete with 4 new toyo proxes
Are these the wheels Morrat was selling?? I was tempted , , , , but I have a set of BBS sitting needing refurb so guess I will just be sending them away some stage in the future.
shedrool83
No not those wheels mate, i found these local.I was in the same boat my 15" bbs needed a refurb and new tyres and these worked out cheaper so i'll be selling mines soon.Tedswagon wrote:Are these the wheels Morrat was selling?? I was tempted , , , , but I have a set of BBS sitting needing refurb so guess I will just be sending them away some stage in the future.
shedrool83
Love a black headline. Great work. Forget about the banger!
shedrool83
shedrool83
Cheers Mickmagpie wrote:that dye is murder to get off ya hands like , good work as usual ... it's all about attention to detail
My hands seem to always look dirty no matter how hard i scrub them so a bit more black marks on them isn't a problem
The only time i get them totally clean is if i'm off work for a week or two
shedrool83
shedrool83
A year nearly to the day got i posted this and its finally in paint.
Wee summary since most of the pics have disappeared
My first attempt of painting a whole car from start to finish.Few runs in the clearcoat to sort out and a colour sand but quite happy with it . I'll do the door checks and the engine bay when the engine comes out again .I did plan to keep the car silver but marrakesh brown came out my mouth instead of silver at the paint suppliers.
Wow, looks great, totally transformed.
shedrool83
shedrool83
shedrool83
shedrool83
Feck..... it's like a mirror. Brilliant work. Looking forward to seeing this in the flesh.
shedrool83
- TurtleDesignTech
Looks excellent. Top work.
shedrool83
Cloggy Saint
wow, looks great. Very quick transformation too.
shedrool83
