Inkeys '87 325i cabriolet
inkeys
Thu Aug 30, 2018 2:00 pm
Thanks for the advice. The Wiki helped me hugely too. Just bought my first E30 after owning various ///M cars and Z3s, Z4s.
She's a Zinnober Red, 1987 chrome bumpered, manual 325i with 71k miles on the clock. Can't wait to get driving her.
Satan
Thu Aug 30, 2018 3:04 pm
I won't ask how much you paid for it, looks lovely.
inkeys
Thu Aug 30, 2018 3:10 pm
Satan wrote:I won't ask how much you paid for it, looks lovely.
I'll let you guess, but I paid what I think it's worth, so am a happy man 8)
Thu Aug 30, 2018 5:04 pm
Wow !!!! They are still out there I see.
If your happy then it has to be worth it mate. :cool: :cool:
inkeys
Thu Aug 30, 2018 9:12 pm
Thanks. I'm very happy indeed! :D
Satan
Fri Aug 31, 2018 8:06 am
Black buttons on the seatbelt stalks?
Gert_8
Fri Aug 31, 2018 12:42 pm
Tidy! What did you buy it for - as an owner of an equally good example I would be interested, please. PM me if you don't mind.
aimlessrock
Fri Aug 31, 2018 12:46 pm
that's beautiful
E30 320i Convertible (1989)
190 Mercedes (1988)
ah
Fri Aug 31, 2018 9:16 pm
That is one nice cab,well done ! You need to get the plastic cap to cover the front bumper mounting nut and ditch the bottle tops for a set of bbs cross spokes unless your after originality.
inkeys
Sat Sep 01, 2018 9:08 am
ah wrote:That is one nice cab,well done ! You need to get the plastic cap to cover the front bumper mounting nut and ditch the bottle tops for a set of bbs cross spokes unless your after originality.
Cheers! Bumper cap kindly ordered through Brutus. Wheels I actually quite like!
inkeys
Sat Sep 01, 2018 9:10 am
Satan wrote:Black buttons on the seatbelt stalks?
Missed that when looking. Need to check when I get the car, but is that wrong?
SiamLars
Sat Sep 01, 2018 11:47 am
What a beauty. Congrats. :drive:
Cloggy Saint
Sat Sep 01, 2018 1:29 pm
So very wrong! They should be red.
Gavla
Soooo verrrrrry wrong... :mad:
Good looking car... :D
inkeys
Sat Sep 01, 2018 8:37 pm
I can tell being on here is going to quite funny :D
Satan
Sat Sep 01, 2018 9:32 pm
inkeys wrote:
Cloggy Saint wrote:
inkeys wrote: Missed that when looking. Need to check when I get the car, but is that wrong?
I can tell being on here is going to quite expensive :D
;o)))))
Sat Sep 01, 2018 9:55 pm
that's a nice looking chariot mind , the roof looks new 8)
inkeys
Sat Sep 01, 2018 10:31 pm
Satan wrote:
inkeys wrote:
Cloggy Saint wrote: So very wrong! They should be red.
;o)))))
I already knew that.
inkeys
Sat Sep 01, 2018 10:32 pm
magpie wrote:that's a nice looking chariot mind , the roof looks new 8)
Thanks. Don't think it's more than a few months old. :D
Satan
Sat Sep 01, 2018 11:47 pm
I use this to protect the vinyl and the dash you can also get it in spray form.
inkeys
Mon Sep 10, 2018 4:29 pm
Picked up the 325 today. Lovely drive home and the engine is a real peach. Huge smile on my face all the way back :)
A few minor jobs to sort out over the coming months. Some essential, some nice to do.
- New springs/shocks: suspect these are the originals. Bottomed out at the front on speedbumps, so wouldn't hurt.
- Temp gauge not working.
- Replace plastic trims on hood.
- Replce rubber window strips if possible along rear.
- Repair drivers seat release as the back currently doesn't move forward.
- Replace boot strut.
- New timing belt, thermostat, water pump at some point.
- Also engine block coolant plug gasket, coolant refresh, drive belts dist. cap and rotor.
- New gear stick bushes.
- Check brakes. Possible updated hoses.
- Inspection 1.
Satan
Mon Sep 10, 2018 5:06 pm
Regarding the seat take the back cover off, two screws on the bottom and the plastic bit on the lever just pulls and the surround pops out you can on the drivers seat work the back over the metal lever if not there is a screw inside and it unclips.
The cable has either snapped (you can buy replacements) or has come adrift while you are at it check the tightness of the screws that hold the seat back.
Also fit a switch to the antenna power circuit so when you aren't listening to the radio you can lower it.
I got my boot strut from SGS some people have had issues with them not fitting so check the numbers.
Which plastic trims on hood?
Rear trim do you mean the ones with the flappy rubber bit over the door pillar?
Tedswagon
Mon Sep 10, 2018 5:29 pm
seat assembly,
[youtube][/youtube]
[youtube][/youtube]
Tedswagon
Mon Sep 10, 2018 5:31 pm
I think your car has been lowered a bit already. Looks a bit lower than standard - could be wrong!
shedrool83
Mon Sep 10, 2018 5:58 pm
I like that, look very clean.
inkeys
Mon Sep 10, 2018 7:45 pm
Satan wrote:Regarding the seat take the back cover off, two screws on the bottom and the plastic bit on the lever just pulls and the surround pops out you can on the drivers seat work the back over the metal lever if not there is a screw inside and it unclips.
Thanks. Looks an easy fix on the seat then. Will check all when in there too. Interested in the antenna switch idea so will investigate.
Struts wise I've used SGS before and found them to be pretty good so will be dropping them a line soon.
The trim is the larger, flat plastic covers at each forward point of the hood plate. One is cracked so I may as well replace both and have a spare. Is the rubber supposed to be flappy underneath then?
inkeys
Mon Sep 10, 2018 7:46 pm
Tedswagon wrote:seat assembly,
Really helpful; many thanks :thumb:
inkeys
Tedswagon wrote:I think your car has been lowered a bit already. Looks a bit lower than standard - could be wrong!
Or all the springs are knackered!
inkeys
Mon Sep 10, 2018 7:48 pm
shedrool83 wrote:I like that, look very clean.
Thanks. What surprised me most was the lack of squeaks, rattles or taps from a car this old. More space for that great exhaust note :D
Satan
Mon Sep 10, 2018 8:01 pm
Post a photo up of the trim you want to replace to give us an idea, to cut power to my antenna I fitted a make or brake (old rear screen heater switch with the decal rubbed off) in to a spare socket above the stereo.
inkeys
Mon Sep 10, 2018 9:10 pm
Trim image here. It's the top part.
Also see the lower left rear window rubber trim. Is this easily replaceable too?
Satan
Mon Sep 10, 2018 9:57 pm
Ah the flappy bit post a wanted ad up the rubber trim just pulls out iif you follow it towards the door there should be a little flappy bit on the B pillar. Looks like a lot of little bits that need doing tot he car.
inkeys
Mon Sep 10, 2018 11:19 pm
Any ideas if its part 7 or part 9 for the weather strip? I'm guessing 9.
Satan
Tue Sep 11, 2018 7:41 am
The inner has the little flappy bit, they sometimes break off.
https://www.pelicanparts.com/More_Info/ ... 42-824-BOE
inkeys
Thu Sep 13, 2018 1:32 pm
Just back from my specialist. They got her up on the ramps and all looks good under there. Going to waxoil the sills when she's in for some work.
Booked a full Inspection 2, new timing belt, water pump gaskets etc. While in we're going to replace the fuel lines as there's a slight whiff of petrol. New head bolts and gasket, fix temp gauge and central locking, new springs and shocks (prob B4 and oem springs) all round plus subframe bushes, wishbones and control arms. Also going for a new windscreen weather strip, thermostat and alt/power steering belts.
Once all that little lot is done I'll be happy and can then fettle other little bits and pieces here and there.
