Power steering pump bad ?
fannyj
Post Sun Feb 12, 2006 12:30 am
Here's the deal, when i turn full lock, i can hear whining/sqeeking which eventually becomes a groaning noise. I flushed the ATF fluid (as it was murky) anf check around for leaks etc. Could it be the pump ?
blingsta
Boost Junkie
Post Sun Feb 12, 2006 3:12 pm
it can only be one of 2 things.... bad pump, or steering rack... i had same problem and changed the pump as its easier and cheaper, unfortuneately, prob was still there so changed the rack and its all quiet now
TheDutch
Holding the steering on full lock is the best way to destroy the pump, I would suggest you try not to do so. And as long as it is providing adequate assistance I would be inclined to leave it. If it is becoming excessively heavy/groaning at low speeds you might have cause for concern. Why not keep an eye out for a second hand spare if you are worried?
charlE30
Post Sun Feb 12, 2006 4:03 pm
fannyj wrote:Here's the deal, when i turn full lock, i can hear whining/sqeeking which eventually becomes a groaning noise.
Bugger mine does this to, I thought it was the pump belt slipping. Is there any way of telling exactly which part needs replacing?
BMW F31 335d xdrive
Post Mon Feb 13, 2006 12:02 am
The groaning comes from the pump, which is being overloaded. The handbook specifically warns about keeping the steering on full lock for more than a very few seconds.
fannyj
Post Mon Feb 13, 2006 6:11 am
ok thanks, guess i won't be full-locking anymore! 8O
Will have it checked though..
