Mine are hard,very hard.. you cant bend em with yer hands.. you think these would still warp and cause vibration?
Ive still got a lil vibration going on and am exausting all avenues on the cause..
New drop links fitted
Rear sub frame bushes replaced
Diff bush needs replacing..not bad but will need doing soon
17'' Pina reps
Plastic spigot rings
All nearly new tyres
wheels balanced recently.. and not done at yer local cheap garage either..
Its not just through the steering wheel and it only happens between 60-70Mph
Will check if it still does it when ive got 4x peeps in ASAP & change the wheels over to see if its them
Im starting to think il never get rid of it
