Coolant leak...
Gavla
Post Fri Jun 29, 2018 5:29 pm
Bit of an odd one to me... I seem to be losing coolant but have no idea why or where from...
It is also not consistent loss... I noticed the light was on so checked and the coolant tank was practically empty... filled it up and have driven 25miles and all good so far...
Any ideas / suggestions?
Satan
Post Fri Jun 29, 2018 6:21 pm
Check the hose and connection under the coolant tank also check the tank for any hairline cracks.
All these hose have a tendency to shrink, perish and start to leak. If you can't find the leak you can buy a UV dye to put through the system.
blazed
Post Fri Jun 29, 2018 6:31 pm
also worth checking your heater valve isn't leaking
Gavla
Post Fri Jun 29, 2018 11:33 pm
thanks gents :D
j4gz
Post Sat Jun 30, 2018 9:31 am
also check the water pump hose that could be catching on the fan and made a hole .
Post Sat Jun 30, 2018 2:21 pm
blazed wrote:also worth checking your heater valve isn't leaking
As in the footwells ?
blazed
Post Sat Jun 30, 2018 4:07 pm
Indeed, i should have said heater valve and matrix. :D
