Advice
Post Fri Jan 26, 2018 3:53 pm
We have a road trip darn Norfolk in the summer ( ? ) and I have been busy collecting parts for a re-vamp of the cooling and electrical systems and have a list here so far;
Radiator
Water pump
Thermostat
Fan
Viscous coupling
All hoses
Temp sender
Cam cover gasket
Coil
Cap
Arm
Leads
Plugs
Oil
Filters
Auto box oil
Auto box filter
Battery
All light bulbs
Drive belts
ISO Fix system all ready to go in
Sink
What have I missed??
New brakes all around 1000 miles ago
4 new tyres 1000 miles ago
Cheers Mart.
Satan
Post Fri Jan 26, 2018 4:02 pm
VED
Insurance
Flowery blanket for the wife
Flask for the wife
Ear defenders to protect you from the moans of said wife
Post Fri Jan 26, 2018 4:15 pm
Insured 365 as my back up.
VED ?
My wife loves the Baur.
Post Fri Jan 26, 2018 6:30 pm
I'd say the list needs a trim.
Fan? It's a lump of plastic, and lasts thousands of years.
Never seen a duff E30 coil yet, and the leads and temp. sender are best left well alone, unless they have a known problem.
Cap and rotor dependant on condition after examination, and the only bulbs I'd replace are ones that are showing signs of the glass turning black.
One thing you might do, while the radiator is out of the way, is to check that the crank position sensor hasn't seized in its mount, and can be easily and quickly changed if ever required. It's a good idea to have a spare tucked away on board somewhere as well - it's the one part that you can't anticipate is going to fail, that can't be bodged or bypassed, and will stop you dead.
TBH, I'm not sure I'd do any of this for a trip from Leeds to Norfolk - a 5000 mile European road trip, maybe.
Still haven't done anything about an ISOfix for the E39! Grandson's three months old now, so must get on with it.
Satan
Post Fri Jan 26, 2018 6:41 pm
VED Road Tax
Post Sat Jan 27, 2018 3:14 pm
The fan has blades missing hence the change , the bulbs (most ) are going black and for the price will be swapped out.
As for the rest, once all of this is done I will have peace of mind and can concentrate on the body a bit more.
Is it worth changing the sensor now whilst I have good access to it ? and where is it ? cant find the part no
Cheers Mart.
arrisbmw
Post Sat Jan 27, 2018 3:57 pm
THAT'S good point about the crankshaft sensor. might have to look out for a spare.
what about spare set of fuses. and a short length of wire in case the fuel pump relays packs up. find out what pins you need to jump in f/p/r socket. or even spare f/p relay.
jump leads are always handy for making friend,
oh and long extension bar wheel wrench, they are always too tight to remove with the piddly thing in the boot . and a power full torch. hi vis jacket. and a mobile phone lol
Post Sat Jan 27, 2018 4:00 pm
"Sink
What have I missed?"
Plug for sink. :wink:
The crank sensor (on later M20 engines, at least) is mounted on the front of the engine, pointing down on the toothed wheel fitted to the end of the crank - a cylindrical item bolted to the block.
Post Sat Jan 27, 2018 6:01 pm
Mine is the webber M10 and I cant find one on E-bay etc.
Got the Halfords tools and other stuff , fuse`s by the dozens, jump leads to start a bus and also covered for breakdown things even at home or as a passenger.
Keep it coming please , I dont want to miss a trick.
kieran325
I did a 1200 mile trip to Germany and back in a 1988 E30. Didn't change anything and carried spare bulbs,belts and nothing else.
Post Sat Jan 27, 2018 6:16 pm
This is all about getting things right for the future and not this one off.
Up until now, all she has done is local stuff and that will change as me and the wife intend to use her much more in the future so replacing relatively cheap parts now , will let us evaluate what is to do in the future.
I`m here for the long haul......... :D :D :D
Post Sat Jan 27, 2018 6:18 pm
kieran325 wrote:I did a 1200 mile trip to Germany and back in a 1988 E30. Didn't change anything and carried spare bulbs,belts and nothing else.
But you must have had confidence in the car in the first place ??
arrisbmw
Post Sat Jan 27, 2018 6:19 pm
i think on your engine there might be 2 crank sensors, check out wiki onhere.
arrisbmw
HartgeH27
Post Sat Jan 27, 2018 7:10 pm
Mart, try Jaymic in Cromer, they are 2002/M10 specialists.
Post Sat Jan 27, 2018 8:33 pm
If it's a Weber carbed M10, then we're going back to early '70's technology. The only 'electronic' management on that was the sophisticated OEM carb., and that's been replaced by a mechanical one.
If it wasn't for the electronics replacing the points in the distributor, it would be back to early '60s.
There won't be a crank sensor on this car (except for one purely for diagnostic purposes), nor much of the other stuff that gives known problems on E30s.
The ignition amp. is probably the weakest point on this engine, as regards stopping it running. Even a duff fuel pump can be bypassed by filling the screenwash bottle with petrol, plus a little re plumbing and wiring.
The problem with changing some of the parts that you refer to, is that parts of the quality of the originals are no longer available, especially from ebay and aftermarket suppliers.
TriggerFish
Post Sat Jan 27, 2018 11:00 pm
arrisbmw wrote:THAT'S good point about the crankshaft sensor. might have to look out for a spare.
If you're going that far, I'd suggest some shoes laces/string in case the throttle cable (or a bracket for something non-important) snaps. (My throttle cable snapped, and I didn't have spare laces/string, so had to be recovered off the side of a dual carriage way in rush hour! Could have been on my way in minutes if I'd had those with me!)
Post Sat Jan 27, 2018 11:22 pm
TriggerFish wrote:(My throttle cable snapped, and I didn't have spare laces/string, so had to be recovered off the side of a dual carriage way in rush hour! Could have been on my way in minutes if I'd had those with me!)
Wedge the throttle stop to give an idle speed of 3000 - 4000 RPM, and off you go. You'll get a few black looks while waiting at lights, and you aren't going to do your clutch any favours, but you'll keep mobile.
Post Sun Jan 28, 2018 2:55 pm
Brianmoooore wrote: The problem with changing some of the parts that you refer to, is that parts of the quality of the originals are no longer available, especially from ebay and aftermarket suppliers.
Point taken here and I have been careful to buy parts with a name to them also the hoses were from Cotswold on here and just as cheap as e-bay.lol.
It`s more an investment in the car for the future as this car is staying with me for a very long time , I hope and I want it right for future trips as well.
I chose this model with the M10 and Webber for it`s simplicity not for speed (I have a 330ci for that) but for the laid back style of driving it dictates and it`s an engine I know I can work on.
Cheers Mart.
