No Spark!!! 325i
What do we think?
immobilised
1
50%
put it in the bin
1
50%
ecu
0
No votes
Total votes: 2
Drury96
Post Tue Jan 23, 2018 9:59 pm
Good Evening Everyone!
- Never posted on here before so please correct me if this is the wrong place to post and bare with me if i don't work out how to reply :mad: ..
So.. long story short, I bought an E30 325i Touring a few months back.
I was told it was a good runner etc until he started taking bits and bobs off for his other project ( no running proof)
However, i have worked my way around replacing everything missing in the engine bay with known working components,
still no joy.
- I have 12v at the coil, and switched 12v at pin 1, all earths and other lives ok to the eco, Known good coil, only tonight switching it with my working coil off of my 316.. known working crankshaft sensor and its getting fuel just fine.. so any other ideas out there? I've also got 12v on the green wire at c101 plug, and 12v at the both sides of the coil with ignition on, as mentioned above..
Only thing I'm left to think, is ecu, or could the car still be immobilised somewhere? or do i have to much power in places for this to be immobilised? (ICV is bussing on ignition on too )
Thanks in advance!! :cry:
Satan
Post Tue Jan 23, 2018 10:21 pm
So it doesn't turn over at all I assume?
We need Brianmoooore on the case.
Drury96
Post Tue Jan 23, 2018 10:23 pm
Satan wrote:So it doesn't turn over at all I assume?
Sorry mate, yes.. turns over, compression etc all good..
Sparks when i first turn ignition on.. but nothing when turning over,
written this problem probably 100 times today so I'm missing bits out by accident!
Drury96
Post Tue Jan 23, 2018 10:35 pm
Check that there's still 12 volts on the coil + terminal while you're cranking it over. Faulty ignition switch isn't unknown.
Drury96
Post Tue Jan 23, 2018 10:36 pm
Brianmoooore wrote:Check that there's still 12 volts on the coil + terminal while you're cranking it over. Faulty ignition switch isn't unknown.
There is mate! 12v at the coil ignition on and also cranking...
Drury96
Post Tue Jan 23, 2018 10:42 pm
Check whether the fuel pump is running while you are cranking. Not actually interested in the pump, which you can't quite get at on a touring without removing the rear seat base hinge rail, so check for power at the inner terminal of fuse 11, preferably with a 12 volt bulb.
drury the post whore
your in the best hands , facebook mechanics will have you checking tyre pressures .
Drury96
Post Tue Jan 23, 2018 10:43 pm
Brianmoooore wrote:Check whether the fuel pump is running while you are cranking. Not actually interested in the pump, which you can't quite get at on a touring without removing the rear seat base hinge rail, so check for power at the inner terminal of fuse 11, preferably with a 12 volt bulb.
i can slightly hear the fuel pump when cranking mate, plus my plugs are getting soaked if i crank for too long..
Drury96
Satan
Post Tue Jan 23, 2018 11:42 pm
magpie wrote:drury the post whore
You mean flat tyre so fuel collects to one side of tank car won't fire. Genius, just needs air.
Drury96
Post Tue Jan 23, 2018 11:45 pm
leave it out :roll: winkeye
Drury96
Drury96
Post Tue Jan 23, 2018 11:48 pm
if i’m completly honest, i tried signing up today to post about this, and it said i already had an account, i must of signed up in 2015 and forgotten about my account!!
Drury96
Post Thu Jan 25, 2018 8:45 pm
turned out to be the wrong relay in the place of dme relay Brian , hong kong fooey off here fixed it ., as i read on f/b
Drury96
Post Thu Jan 25, 2018 11:20 pm
magpie wrote:turned out to be the wrong relay in the place of dme relay Brian , hong kong fooey off here fixed it ., as i read on f/b
as above.. i checked the relay was functional, etc.. but didn’t check if some idiot had changed the dme relay.. for what ever reason haha!
Drury96
