folding mirrors sorry if duplicate post
arrisbmw
Post Sun Jan 07, 2018 10:30 pm
Hi do my mirrors fold in manually ? please
1.6 i 1989.
can,t seem to move them.
thanks
Satan
Post Sun Jan 07, 2018 10:44 pm
Should do.
Post Sun Jan 07, 2018 10:46 pm
They did when the car was new! 'White rust' has probably seized them, so several doses of your favourite rust releaser required.
arrisbmw
Post Sun Jan 07, 2018 11:32 pm
cheers Brian , white rust ? whats that from ally
Satan
Post Sun Jan 07, 2018 11:37 pm
arrisbmw wrote:cheers Brian , white rust ? whats that from ally
Ally flakes and sticks to other metals materials, try some WD40 wit PTF or ACF50
Is the paint pealing on the brackets?
Yeti
Post Mon Jan 08, 2018 12:15 am
white from ally is the oxidization
arrisbmw
Post Mon Jan 08, 2018 4:53 pm
paint starting to peel on brackets, but not to bad, lubbed up with trans fluid has good creep, used a little black grease(c.v joint type ) on the metal moving part inside underneath. you need a bright light and close inspection
to see it, there is a dipple where the mirror housing sits in when at home position works fine now.
thanks you all for advise.
