headlight switch ?
https://www.ebay.co.uk/itm/Halogen-Sche ... 0005.m1851
Can these be made to be used in right hand drive form?
Cheers Mart.
Cheers Mart.
Cloggy Saint
cheap shite ! do they come with a free goldfish ?
+ a yard full of scrap turds
steve_k
the trick is to open them up, smoke them yourself, & then reseal themmagpie wrote:cheap shite ! do they come with a free goldfish ?
Satan
Smileys can be adjusted I believe between RHD and RHD as my son fitted a set to his 87 car before he exported it to Germany as it needed to pass the TUV test to get its classic car status.
Cloggy Saint
ChrisHC
- E30Zone Contributor
Yes, they can be although the ads say LHD, I fitted them to my 1987. A bit of a fiddle as you have to loosen the three screws on each one quite a way, but you get a much better result than lens adaptors.Satan wrote:Smileys can be adjusted I believe between RHD and RHD as my son fitted a set to his 87 car before he exported it to Germany as it needed to pass the TUV test to get its classic car status.
I dont want smoked and Mick are you using the same site, as these have cross hairs in your pics?
Cloggy Saint
I'm just a bit tempted as the Baur does not do a great deal of miles and with a touch of sealant to make sure , then it could be viable.
I don't want her to be a concours but maybe this may help her look a bit fresher?
paultv
I fitted a Depo set as a stop gap as my originals were so shot - adjustable left and right, great for me in Germany for a while with UK mot - easy switch, no issues at all - certainly not leaked or corroded, so for the money they ain't bad.
Been on the car for 18 months - and certainly look a shed load better than the old rotten crap I took out.
Paul
Paul
In what way? A new set of adjusters, and a second hand set of E30 lights is normally indistinguishable from new.paultv wrote:and certainly look a shed load better than the old rotten crap I took out.
Paul
Although RH drive E30 lights can be adjusted to give a perfect LH drive suitable mirror beam pattern (unlike my E39!), Factory LH drive E30s use headlamps with different part numbers.
martauto wrote:I dont want smoked and Mick are you using the same site, as these have cross hairs in your pics?
same type of light from china no doubt with unbranded lenses unlike the bosch or hella lenses BMW supply on oem lights , i'd rather buy a set of good clear glass originals and free up the adjusters and change any perished plastic adjuster grommets , a wire wheel on a drill, pair of pliers and mole grips to spin the plasic nut up and down with plenty wd40 and they are brand new again .
Satan
Had to swap the sons lights around what a pain the bulb covers for some reason decided to weld themselves to the lamps WD40 and a vice helped free them.......
paultv
The lens' were all cracked, stone chipped and milky, low light output, damaged surrounds - the cheepy deepies look crisp - and whats more I can see where I'm going - perfect for now until I find a replacement set in decent shape, which most are not.
Paul
Paul
Finding a first class set nowadays will be expensive and Depo have a decent name so lets see what Santa may bring.paultv wrote:The lens' were all cracked, stone chipped and milky, low light output, damaged surrounds - the cheepy deepies look crisp - and whats more I can see where I'm going - perfect for now until I find a replacement set in decent shape, which most are not.
Paul
