Brake servo/master cylinder relocation behind dash
B5234FT
Post Fri Jul 21, 2017 11:44 am
Hi,
I'd prefer not to lose the servo, or to have it in the engine bay by the headlight. I've seen a lot of references to siting it behind the glovebox, but few pictures or detail.
Has anyone done this? What servo and master cylinder did you use and do you have any pics of the bracketry?
WYZEUP
Post Mon Jul 24, 2017 5:18 am
I have done such a swap.
Ergen motorsport put togethera kit that you can use with servo and all, isnt cheap but makes the whole process very simple.
I will try and dig up some pictures as photobucket has been an ass with hosting now
B5234FT
Post Mon Jul 24, 2017 10:53 am
Thanks WYZEUP, much appreciated. I know, PB has managed to single handedly ruin the internet.
I've seen the Ergen kit, but it's a little rich for me and there are no details of what servo or master cylinder they have specified.
WYZEUP
Post Mon Jul 24, 2017 9:28 pm
Try this....is a couple of photos from while i was installing the booster.
https://photos.app.goo.gl/4IAOnOcNYhddG6X52
It is expensive for what it is, but for ease and piece of mind it works well. was sceptical at first because of the size of the booster, but which some good pads and the matched master cylinder i am quite happy with the braking capabilities.
Only annoying part was having to figure out where to put the reservoir.
manse73
Post Mon Jul 24, 2017 11:38 pm
Speak to ross2009 he has a build thread with a Chevy v8 in an E30
He has his servo behind the glovebox and it works well. I know, I've been in it
bruv chariots rule
B5234FT
Post Tue Jul 25, 2017 9:43 am
What master cylinder and servo did you use in your car WYZEUP?
WYZEUP
Post Sun Jul 30, 2017 11:58 pm
I ordered the booster and master from Ergen as well....they matched the master cylinder size to the brakers that i have fitted.
you can fit an e30 booster and master to the bracket if you like, takes a little beating of the firewall to fit tho
V8turd
Post Fri Dec 07, 2018 1:29 pm
I have had the servo mounting bracket modified to rotate the servo 90 degrees. It now lives where the glove box used to.
Renault Clio servo
Post Fri Dec 07, 2018 2:16 pm
Sorry to butt in, our photo posting is really simple now guy`s, have a look at our guide and you can up-load from any device.
Welcome to the Zone as well mate :cool: :cool:
B5234FT
Post Fri Dec 07, 2018 3:53 pm
Yeah I'm going the same way now with the clio servo, gets it done for now.
09asm
Post Thu Jul 30, 2020 3:43 am
Bringing up a blast from the past but what car is the actual brake servo/booster that Ergen Motorsport from? I know it's an ATE one but does anyone know any more info on the booster itself/what car it is for/part number etc??
I have the booster relocation kit for under the dash but dry fitting it the other day with the standard e30 booster, i will need to chop way too much glovebox and it will hang fairly low down to the foot well. The standard booster has a 11"OD/10" diaphragm. I believe the "miniture" Ergen Motorsport boosters they were selling were 7" but that's it.
Oh and Ergen Motorsport no longer exists so can't find out anything there/purchase.
thanks in advance guys
McTubs
Post Sun Aug 14, 2022 9:21 pm
Hi there,
If anyone is having the same issue as the guy who posted last. Replacing the Ergen booster. You can bolt in an e90 booster and master. Fits lovely with great pedal feel. Also mine cost me all in £26. Bargin.
Just to add had nothing but problems with the parts I got from Ergen, not suprised they not longer exist.
Post Mon Aug 22, 2022 8:44 am
The 'minature' servo Ergan used to supply was from an early VW, Mk1 Golf possibly. Old old design and personally id always look to use more modern parts, ive done direct comparison between Mk2 Golf and 2001 Clio on the same car and its a big difference so if you can get an E90 servo in there thats what id be doing
V8turd
Post Sun Oct 30, 2022 1:36 pm
I have servo relocation bracket purchased from 26 Street in Australia, Limited run from what I can gather
This is renault clio servo with 750 master cylinder. The glove box can be fitted if the rear is notched.
V8turd
Post Sun Oct 30, 2022 1:39 pm
This is my engine bay.
I didn't want to use e34 stuff and have servo behind headlight with all thr brackets and linkages etc because it looks busy and naff in my opinion. Not to mention the extra brake bars and pivots that could be extra areas that could flex or fail . So I chose the servo behind glive box option 8)
