Thermostat question
Jona1971
Post Wed Jun 14, 2017 6:16 pm
Hi, I bought a new thermostat which is a Meyle item and is labelled 71 degrees C, the old one was 80 degrees C. Is this an issue?
(325i 1986)
Thanksa™‚
Moredoor autos with small engines are cool - but my new m20b25 is awesome!
Jona1971
Post Wed Jun 14, 2017 6:22 pm
Realoem part number is 11531710953 (but says 80CEL) and part number on the Meyle box is the same????
BenHar
Post Wed Jun 14, 2017 9:13 pm
325i should have an 82 degree thermostat.
Ben
Jona1971
Post Thu Jun 15, 2017 6:28 pm
Will it make any difference to the running of the car?
minesapint
Post Thu Jun 15, 2017 10:14 pm
Merle show two for the 325i, 71 degrees & 80 degrees.
It needs the 80 degree stat. Why don't you exchange it for the correct one and avoid any doubt.
There is no way on Gods earth I'd be running an incorrectly rated stat in my 325i.
Jona1971
Post Fri Jun 23, 2017 5:50 pm
Thanks, I returned it. I asked for a replacement, but they just offered a refund instead.
minesapint
Post Fri Jun 23, 2017 11:02 pm
Why are you not buying from BMW parts? they are an inexpensive item, you could have had it fitted by now.
https://www.etkbmw.com/bmw/EN/search/se ... CE/11_0759
Jona1971
Post Sat Jun 24, 2017 8:32 am
Assumed it would be dear, I'll ask Cotswolds.
Also assumed Meyle would know what they are doing.
Jona1971
Post Thu Jun 29, 2017 5:41 pm
Cotswolds £33.
