M20B25 sump gasket question
Jona1971
Fri Jun 02, 2017 12:16 pm
Hi,
I've just had my new sump gasket delivered from Cotswolds. Should I use sealant?
If so, which type?
What is the torque for the bolts when putting back on?
Thanks a™‚
Moredoor autos with small engines are cool - but my new m20b25 is awesome!
BenHar
Fri Jun 02, 2017 2:22 pm
Jona1971
Fri Jun 02, 2017 8:43 pm
That is very useful! a™‚
maxfield
Fri Jun 02, 2017 9:21 pm
Shouldn't be any need to use any sealant, aslong as both surfaces are nice and clean.
chu346
Fri Jun 02, 2017 10:23 pm
maxfield wrote:Shouldn't be any need to use any sealant, aslong as both surfaces are nice and clean.
Thats right, but last time I did one it leaked a little :?
Fri Jun 02, 2017 11:13 pm
If sealant is used, keep it to a minimum. Excess sealant that is squeezed out inside the sump tends to form little balls that are very effective at blocking the gauze on the oil pick up pipe.
maxfield
Sat Jun 03, 2017 9:36 am
If you have to use a sealant, I would use hylomar blue. Is a non setting compound, but is good stuff.
Jona1971
Sat Jun 03, 2017 11:35 am
Thanks chaps a™‚
Yeti
Sun Jun 04, 2017 12:12 am
thin bit of hylomer you should be good
