Hi,
I've just had my new sump gasket delivered from Cotswolds. Should I use sealant?
If so, which type?
What is the torque for the bolts when putting back on?
Thanks a™‚
M20B25 sump gasket question
- Brianmoooore
If sealant is used, keep it to a minimum. Excess sealant that is squeezed out inside the sump tends to form little balls that are very effective at blocking the gauze on the oil pick up pipe.
