Ews ring
chu346
Wed Mar 29, 2017 2:05 pm
Can I fit an ews ring to my e30 ignition barrel?
If so, how?
jmc330i
Wed Mar 29, 2017 2:49 pm
The ring won't clip to the barrel, but you can modify/cut the column shroud so the ring sits in the right place.
There was pictures on here of how I did mine, but it was so long ago I don't know where or what thread they are in.
James
'91 325i Sport
'93 318i touring 16v
chu346
Wed Mar 29, 2017 2:51 pm
Does the E30 ring need to come off?
jmc330i
Wed Mar 29, 2017 3:22 pm
E30 ring?
James
'91 325i Sport
chu346
Wed Mar 29, 2017 3:38 pm
Plastic cover around the Barrel
jmc330i
Wed Mar 29, 2017 4:00 pm
Ah gotcha. No pretty sure I left mine as it was, the EWS ring just sits over it. Cut a slot in the shroud for the little plastic rectangular bit to pass through (with the wires) and you might need to dremel part of the shroud to follow the curve of the ring - just do a little at a time until the ring will then hold itself in place.
I'll look for some pics when I get home.
James
'91 325i Sport
chu346
Wed Mar 29, 2017 4:26 pm
Ok thanks
jmc330i
Thu Mar 30, 2017 6:00 am
Now I look back at the pic, there is a small ring that comes off from the shroud when you cut the slot for the wire - you can see the gap around barrel.
On the vertical opposite the slot is where you'll need to dremel the shroud to follow the curve of the ring. It's not much and if you do it in small stages you can get a tight fit so the EWS ring is held in place.
James
'91 325i Sport
chu346
Thu Mar 30, 2017 6:37 am
Thanks, for digging that out.
My ring is from an E39 and it looks like the e30 ring needs to be removed to have any chance of fitting.
Do you have a picture of it fitted?
Thu Mar 30, 2017 9:22 am
One of mine
jmc330i
Thu Mar 30, 2017 9:47 am
^^^ Exactly what mine looks like :D
James
'91 325i Sport
chu346
Thu Mar 30, 2017 8:26 pm
Thanks, but mine didn't come out that good :?
