Touring sideskirts
Scotty200
Post Mon Mar 06, 2017 6:00 am
Hi all, I feel this is a silly question I wanna remove my touring sideskirts am I right in thinking it's just drill out the two pop rivets at the rear then pop off the clips from the rear towards the front?
Cheers scott
jonny323i
Post Mon Mar 06, 2017 8:07 am
Basically yes
Touring for life
Scotty200
Post Mon Mar 06, 2017 8:54 am
Quaser
Post Mon Mar 06, 2017 9:20 am
do you want to sell them?
Post Mon Mar 06, 2017 9:50 am
Push the centre pins through the pop rivets with a small parallel punch. No drilling required.
Clips along the sill are a sort of ratchet design and need to be 'released' to remove them. Close inspection of one should show you how to do this.
Scotty200
Post Mon Mar 06, 2017 10:42 am
Sorry the side skirts are not for sale as there my only pair, after info of removal so I can fix a previous owners shit job at welding looks like they covered the rust with under seal then welded plate over the top!
Thanks Brian for the tip if I punch them out does that mean I can reuse them again?
Sanchez
Post Mon Mar 06, 2017 3:19 pm
They a two part plastic expanding rivet. Work like a raw plug in the wall with a screw in it.
Push the centre out and use a flat blade to lever the rivet out. If you retrieve the centre part can be reused or plenty can be bought ebay.
