Hi, I searched and searched. Googled and found some info but not much.
Can you reuse the OEM rod and crank bolts? Also, what are the torque specs?
M44B19 rod bolts torque
captain_chaos
reggid
you are not supposed to
E30 325is with M20B31
captain_chaos
Thanks fella, just trying to weigh up the cost of the bottom end rebuild vs a different motorreggid wrote:you are not supposed to
Motorhole
Nope, deffo not supposed to re-use them.
Torque specs should be in here somewhere?
http://workshop-manuals.com/bmw/3_serie ... smantled)/
captain_chaos
Thanks dude, I seen that site but was not sure how trustworthy it was that's all. I know the Bentley manual does not cover the bottom end at allMotorhole wrote:Nope, deffo not supposed to re-use them.
