6 branch manifold
jmc330i
Fri Feb 14, 2014 11:01 pm
reggid wrote:
steve_k wrote:
reggid wrote:i know some pretty high powered m20 engines with a hot tuning manifold. it may not look as pretty but it still seems to perform well
Any links?? winkeye
this engine uses chinese BTB copies im led to believe also the ones i were thinking of are raceland NOT hot tuning as i thought.
259kw - is that really just under 350bhp from a 2.8 M20? 8O
James
'91 325i Sport
'93 318i touring 16v
steve_k
Fri Feb 14, 2014 11:02 pm
How much??
reggid
Sat Feb 15, 2014 1:40 am
jmc330i wrote:
reggid wrote:
steve_k wrote: Any links?? winkeye
its at the wheels so at the flywheel is closer to 400 bhp
E30 325is with M20B31
Sat Feb 15, 2014 12:36 pm
NA? How is this possible?!
Engine spec?
suchy
True Zone Relic
Sat Feb 15, 2014 5:03 pm
ross_jsy wrote:It's a little bit above me, but from what I understand equal length primaries (of the correct length and diameter, there are calculations to work this out) create a scavenging effect as the gases moving through the tube from one opening of the exhaust valve are still in the primary, sucking the subsequent pulse out when the exhaust valves open again.
Does that make sense?
Ahh right that makes a bit of sense! :)
ross_jsy
Sat Feb 15, 2014 5:26 pm
bss325i wrote:NA? How is this possible?!
Engine spec?
14.5:1 compression ratio and 9k rpm according to the youtube video 8O
timmzey
Sat Feb 15, 2014 6:37 pm
Edited for privacy
carpenter
Sat Dec 17, 2016 4:06 pm
Does anyone has experience with these headers maybe? They look like a btb copy.... they sold 37 of them so maybe they are not such a bad copy..?
http://www.ebay.co.uk/itm/STAINLESS-STE ... SwvzRX19RN
Kos
Mon Dec 19, 2016 3:31 am
just another copy of a BTB
www.pukardesigns.com
IG Pukar.Designs
carpenter
Mon Dec 19, 2016 9:59 am
Yes, but there are good and bad copies... :( ,any results on dyno with those, anyone..?
driftmaster808
Thu Dec 29, 2016 4:04 pm
not from China there arean't any good copies
