259kw - is that really just under 350bhp from a 2.8 M20?reggid wrote:this engine uses chinese BTB copies im led to believe also the ones i were thinking of are raceland NOT hot tuning as i thought.steve_k wrote:Any links??reggid wrote:i know some pretty high powered m20 engines with a hot tuning manifold. it may not look as pretty but it still seems to perform well
6 branch manifold
jmc330i
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
steve_k
How much??
reggid
its at the wheels so at the flywheel is closer to 400 bhpjmc330i wrote:259kw - is that really just under 350bhp from a 2.8 M20?reggid wrote:this engine uses chinese BTB copies im led to believe also the ones i were thinking of are raceland NOT hot tuning as i thought.steve_k wrote: Any links??
E30 325is with M20B31
NA? How is this possible?!
Engine spec?
Engine spec?
suchy
- True Zone Relic
Ahh right that makes a bit of sense!ross_jsy wrote:It's a little bit above me, but from what I understand equal length primaries (of the correct length and diameter, there are calculations to work this out) create a scavenging effect as the gases moving through the tube from one opening of the exhaust valve are still in the primary, sucking the subsequent pulse out when the exhaust valves open again.
Does that make sense?
ross_jsy
14.5:1 compression ratio and 9k rpm according to the youtube videobss325i wrote:NA? How is this possible?!
Engine spec?
timmzey
Edited for privacy
carpenter
Does anyone has experience with these headers maybe? They look like a btb copy.... they sold 37 of them so maybe they are not such a bad copy..?
http://www.ebay.co.uk/itm/STAINLESS-STE ... SwvzRX19RN
Kos
just another copy of a BTB
carpenter
Yes, but there are good and bad copies...
,any results on dyno with those, anyone..?
driftmaster808
not from China there arean't any good copies
