Any ideas?! Is there something else in there that would have bolts like this?!
Dips did you lose any bolts before I took it from you? LOL!
Couple of random pics.
That thread has made me quite worried now, look's like that sump is coming off the weekenddobbie82 wrote:something like that happens with m40's....
http://www.e30zone.co.uk/modules.php?na ... ic&t=18155
i know nothing just thought i would try help
.Adammcf wrote:This is an M20.
Does anyone know what they could be off? Should there be something in the bottom end which could have bolts like that apart from the 3 holding the oil pump on?!
Wouldn't wanna try that!Adammcf wrote:Cheers folks. I plan to clean it all up either tonight or tomorrow night so I can swap the blocks over this weekend.
Its going to be fun lifting a block out of the engine bay by hand with no crane and then lifting in this one! lol
Are you certain they are not oil pump bolts? what about the bolts that hold in the level indicator in place and the bolts around that region?Adammcf wrote:The picture makes them look smaller than they are. Theyre about twice the size of the normal sump bolts.jonb wrote:they look like sump bolts. some one must of left them in there when they offered up the sump last time.
