turbo 2.5
john-rambo
Post Tue Feb 07, 2006 10:55 pm
what parts do i need to put a turbo conversion on a 2.5 can i use a 324td manifold and turbo what ecu do i need can i fit 2 head gaskets to keep the old pistons etc
tec 2 man saying NO to chrome bumper and tec 1 wrongness!!!!!!!!!
Kos
Post Wed Feb 08, 2006 12:21 am
money!!!
i wouldnt got the dual head gasket route, if you bottom en is solid with a good c/r a low boost aplication will work well.
Turbo-Brown
Boost Junkie
Post Wed Feb 08, 2006 8:13 am
The CR's pretty low on these engines anyway so no need to muck about with lots of gaskets :)
Fozzymonster's running about 13psi on a stock bottom end :D
The choice of ECUs is endless, Megasquirt's nice and cheap plus has some cool functions like AFR tables, Emerald's got good backup and it pretty easy to install and use (not that MS isn't!)
e30_Turbo
Boost Junkie
Post Wed Feb 08, 2006 12:57 pm
13.2 actually :cool:
Money is first issue, the getting the right parts too, although I'm sure you could buy pretty much all you require of the shelf these days.
Jon-bmw is using the TD manifold so ask him for his opinion on that, MS & emerald do the same job but need vastly different amounts of technical knowledge to get them to work right, MS is certainly a learning experiance, having seen emerald in action I can see where all the extra money has been spent, much more user friendly.
I'm hopeing for 1 bar on my setup, poss by the end of the month and certainly before 25th March......then bigger turbo, exhaust and the new "boost ready" head goes on and I'll see how 1.5bar feels!!
Make sure you read through the "update" thread and tobys "m30 turbo" thread, I'm sure you'll find all the info you could ever need.
And good luck too :D
Mark.
