NEW coolant sensor, shorter than original and not working.
Stevieabz
Post Tue Aug 16, 2016 11:55 am
Bought this as my coolant light would continuously be on even though the coolant was at the correct level. The old sensor was worn and not working properly, but once out the car I could change the check light on or off depending on the position of the cylinder on the sensor.
http://www.ebay.co.uk/itm/111986266507? ... EBIDX%3AIT
New sensor in. Light stays on.. Take it out whilst plugged in. Move the cylinder.. Nothing. The light is now just on no matter what I do.
Any advice welcome.
Stevieabz
Post Tue Aug 16, 2016 12:08 pm
Also, are the check board lights in the center on the roof removable by shorting some pins? I feel like it's quite clever and can sort it's self out? Like it did before with the original one.
Stevieabz
Post Tue Aug 16, 2016 12:46 pm
Okay I may have found the problem. I have purchased the wrong one. I should have got this one. http://www.ebay.co.uk/itm/191084336531
Post Tue Aug 16, 2016 1:44 pm
You've bought the version that fits in the underside of the coolant tank type that is mounted at the end of the radiator, such as E36 rads. etc., and the E30 M40/42 rad.
Because you're mounting it upside down, the light will be on when the tank is full, and off when it's empty.
As you've noticed, there's a slight difference in length.
Stevieabz
Post Tue Aug 16, 2016 2:18 pm
Thanks Brian, What an idiot ay. The new, longer and correct one is on its way.
