Lock part seemingly not part of the lock cyl repair kit
M6luvva
Post Wed Jul 20, 2016 1:59 pm
I've just order a lock cylinder repair kit to recode my driver's door lock to the same as the others in my car.
My mechanic has told me it would be prudent to also get the 'latch', in other words the part in the picture -link below- that is in the bottom right hand corner of the image:
http://www.ebay.co.uk/itm/BMW-E30-Repla ... XQ1eBR5UtN
I'm not sure this is included in the kit I've just ordered from Cotswold (P/N 51219061344). It isn't pictured on the realoem image either...
Where can I get one?
My car has central locking if that makes any difference..
Ta
Chris.
paultv
Post Wed Jul 20, 2016 2:11 pm
I guess you have a Convertible? if so the end bit operates the deadlock, they break easily, the down side is that they are "handed" so all the Euro and American sourced items are for a LHD vehicles, whilst many of the parts are universal, you will be able to do a re code, some are not. I've tried for years to find a RHD repair kit without any luck.
Paul :-)
M6luvva
Post Wed Jul 20, 2016 3:14 pm
Aha - it's the deadlock! So this is the supplemental latch when you turn the key all the way to the horizontal? Mine's a Baur convertible so standard coupe equipment and yes it is the driver's side for a RHD car.
The repair kit from Cotswold was £17. The ebay one is £50, presumably because it includes the latch?
paultv
Post Wed Jul 20, 2016 3:19 pm
Yes that's right, it's a real pain, if the end two pieces which are cast ally or something brake or become really worn it's curtains and you have to use a saloon type lock with no Dead position, crap if the roof is off on a sunny day, anyone can lean in and open the vehicle....
However, if you parts are OK, then you can at least do the re code - I did the drivers door and the glove box and the boot - all different - my cabby is a mongrel indeed!
Paul :-)
BenHar
Post Wed Jul 20, 2016 4:01 pm
Post Wed Jul 20, 2016 4:05 pm
????? Since when has a cab. lock been any different from a saloon?
M6luvva
Post Wed Jul 20, 2016 9:53 pm
Interesting but I'm flummoxed! Is the part I'm after what's referred to as the 'armature' in the Wiki link above and does the lock cylinder rebuild kit include this?
BenHar
Post Thu Jul 21, 2016 12:43 pm
The part number in the wiki link I gave above includes the arm.
Ben
ChrisHC
E30Zone Contributor
Post Thu Jul 21, 2016 3:25 pm
The link in your initial post is to a repair kit which will be the one as supplied by Cotswold. I fitted one last Autumn, you need to be methodical and careful, but the end result is very satisfying.
paultv
Post Thu Jul 21, 2016 6:42 pm
I'm confused also - link at the top of the thread is for a LHD car - surely, if you use it, the end deadlock arm will point the wrong way as it is handed - is it this part you need ??
Paul :-)
jonny323i
Post Thu Jul 21, 2016 7:03 pm
51219061344 I'm pretty sure this is the kit you need its the right hand lock for a rhd car with deadlocks
Touring for life
M6luvva
Post Sun Jul 24, 2016 8:10 am
Just a heads-up to anyone still wondering, the deadlock is included in the repair kit. Confusingly, the schematic on realoem doesnt show it in their picture. All good!
