fuel filler neck
corkie
Post Tue Jun 28, 2016 7:06 pm
mine is rusted out,how do these fit ?any welding required?thanks
e30
Post Wed Jun 29, 2016 12:02 am
They just bolt in.
I have a perfect one for sale.
corkie
Post Wed Jun 29, 2016 6:52 am
How much and where are you based?also do you have the rubber surround ?ta
e30
Post Wed Jun 29, 2016 4:36 pm
i have refurbished ones here , they have been shot blasted, primered and painted
corkie
Post Thu Jun 30, 2016 8:33 am
How much posted?
e30
corkie
Post Wed Jul 06, 2016 9:55 am
Is it a easy fit or not??tank out?
e30
Post Wed Jul 06, 2016 1:34 pm
Wheel arch liner out, one screw to bracket in wheel arch, one bolt to rectangular bracket on floor pan, hose clip on short hose to tank, then manoeuvre the filler pipe down. Remove small hoses on the vent pipe near the top of the filler and it's out.
Remove the filler hose from the tank, make sure the paint is good on and around the stub pipe, apply Waxoil and refit pipe, ensuring that the hose clip is as close to the tank* as possible.
*If the clip isn't tight against the tank, a small triangular void will be formed between the tank, hose and stub, which will be permanently damp, causing the rust which is the semise of many E30 tanks.
corkie
Post Wed Jul 06, 2016 1:48 pm
Phew !somebody told me id have to remove the tank !!much obliged Brian !
e30
corkie
Post Sat Jul 09, 2016 5:12 pm
Is it necessary to put the little plastic tank and all the hoses back or can i get rid? Stub on the tank seems to be ok a little surface rust!
e30
