does the sound of expensive and cheap exhaust same?
markus_74
Post Sun Jun 12, 2016 11:19 am
Hello,
I know boysen and ebersalpaecher is very good quality but the price is very expensive.
After a little bit search I got cheap muffler cost only 40-100eur. They said use high quality Krupp thiessen aluminum steel to repel rust.
I believe this can at least 8 year life in my country climate.
But does this cheap exhaust will have same sound compare to expensive boysen?
I limited my choice to only aluminum steel and avoid stainless steel.
Any advice or experience here?
Thank you
Markus
jslot
Post Sun Jun 12, 2016 7:52 pm
I put a cheap centre section and backbox on my 320, similar cost as you say, I think it was also made of Krupp Thiessen material. It does sound different. It sounds more tinny. The back box was much smaller than the original.
Post Sun Jun 12, 2016 10:13 pm
I suspect the 'aluminium steel' is actually mainly cheap mild steel with an electrolytic thin coat of aluminium-based paint to give it a nice shiny silver finish - for a short while.
I doubt it will last 8 years, but you never know...
markus_74
Post Mon Jun 13, 2016 4:29 am
Any other option as boysen and eberspaecher is rare and expensive? Imasaf? Walker? Asso? Borla? Etc?
Post Wed Jun 15, 2016 4:39 pm
Here in the UK, we often get Klarius exhaust parts, which are I gather Walker/Boysen.
darkchild
Post Wed Jun 15, 2016 7:10 pm
Speedtouch wrote:Here in the UK, we often get Klarius exhaust parts, which are I gather Walker/Boysen.
Klarius are what was Timax, not Walker. For lack of a better descriptive term, they're sh!te. :)
Post Wed Jun 15, 2016 9:04 pm
Yes, that's the one. I've fitted a couple of Klarius parts from Euros to mine (front downpipe section on a Fiat) and someone else's car (back box on a Peugeot), and both fitted perfectly and appeared to be of reasonable quality, so I wouldn't necessarily agree with your description of them.
darkchild
Post Thu Jun 16, 2016 5:57 am
Speedtouch wrote:Yes, that's the one. I've fitted a couple of Klarius parts from Euros to mine (front downpipe section on a Fiat) and someone else's car (back box on a Peugeot), and both fitted perfectly and appeared to be of reasonable quality, so I wouldn't necessarily agree with your description of them.
After fitting one to my old E36 that sounded cr@p and lasted about 1 day outside of it's 2 year warranty I would beg to differ. :(
You get what you pay for. The original lasted 15 years.
Post Thu Jun 16, 2016 11:13 am
Indeed, they may not be up to OEM standard of long-term durability, but for an affordable replacement, they are pretty good I'd say.
pianist
Post Thu Jun 16, 2016 2:11 pm
+1 klarius never again, bought a full system and after two years back box decided to go on its own and separated from the rest of the system and ofcourse it was with the help from its friend rust
Cheap is what cheap does, this is why it is always cheaper to buy expensive parts because you buy them once!
markus_74
Post Sun Jun 19, 2016 9:17 am
I go to buy 323i middle exhaust because it is cheaper than 325i but I don't know the performance, but al least it is eberspaecher brand.
And for rear exhaust I think will have choice between ta technix and Bosal, any advice?
