Had my first MOT today after my mini restoration car passed with only 2 advisories which was good,however the tester pointed out my rear lights could have goldfish in them!!!
I presume the seal is gone but I have no water in the boot but I.m parked rear end down on the drive!!! So maybe just lucky ... I had the lights off recently and the seals looked pretty good maybe they just need tightening ?? Can I get the seals at the dealer!!!
Water inside rear lights
BHadley
Yes ask Cotswolds on here, surprising price for what it is
jcm325
My lights are slightly cracked so if seals are expensive I don't want to put new seals on. ..
I presume all e30 lights are interchangeable? Or are touring and cabriolet different.
jcm325
Does anyone know if all e30 rear lights are the same? Or are touring and cabriolet different?
Any info would be great. ...
Cloggy Saint
BHadley
There is the " cheaper possible fix of clean up seal then rub general purpose grease into the seal"
Is it a lot of water or a small amount?
What type is it... Saloon? touring? Got a sunroof? Etc
andysheep
Just NO bathroom sealant,its smells vineary because its got acidic base,it will eat the paint then metal
jcm325
Water was only in the orange indicator section which is cracked both sides....think this is the cause as I checked the seals before I refitted them...
New lights for me I think! !!
