Rigging up old Blaupunkt system, wiring Q
jimbom30cab
Tech 1 freak
Post Mon Mar 07, 2016 9:33 pm
Hi
The head unit has a switched power output. Should i use this to power the switched power to the equaliser and amps. Or should I wire them straight to the ACC switched power on the car.
I'm running a Denver, 2 quad amps and an equaliser if that makes any difference to the load on the switched power
Jim
jimbom30cab
Tech 1 freak
Post Tue Mar 08, 2016 7:09 pm
thanks........................
Z3I
Post Tue Mar 08, 2016 7:38 pm
I don't know the Denver, but the switched power outlet is usually for the power aerial. Have a search on the internet for the correct power arrangement, you don't want any smoke!
Post Tue Mar 08, 2016 8:01 pm
AFAIK, these amps. have a direct, fused connection to the battery for their high current requirements, and are switched on and off by a 12 volt signal which consumes no significant power. The switched live from the radio is used to control the antenna and the power amp.
jimbom30cab
Tech 1 freak
Post Tue Mar 08, 2016 9:24 pm
Thanks v much Brian, much appreciated Sir !
