Windscreen washer jet T piece leaks.
tomstickland
I've found that the T piece for the windscreen washer jet is pissing water out of two small holes in it. I guess that these are pressure relief holes? Does that mean that the jets are blocked? Or is it a fault?
MONSPORT42
Mine's doing the same at the moment. My jets were blocked and I cleared them with a needle this morning but the T piece is still squirting. It happened a few years ago and I replaced all the bits. I think I put in too much screen wash and a crusty residue has built up. I intend to empty the reservoir and wash it all through with warm water and see how it goes
YOUR LEFT FOOT'S FOR BRAKING
Common fault. Needs replacing. Not expensive from the dealer.tomstickland wrote:I've found that the T piece for the windscreen washer jet is pissing water out of two small holes in it. I guess that these are pressure relief holes? Does that mean that the jets are blocked? Or is it a fault?
tomstickland
OK, thanks, I'll replace. Meanwhile I'm going to jubilee clip a glove over the holes. I'm fed up with the Grey world I see through the front screen.
jayE30lover
just to let you know mate, mine had the same problem, bought new piece from bm and they were litterally pence mate!
318i: kicken Sie ein Esel-Baby!
Dan318-is
as brian says common fault; mine failed the other week, my local dealer even had it in stock
was less than four pounds
So common that they probably won't even need to look up the part number.
tomstickland
Great, thanks for the info.
Why do they fail though? Do they seize up, go brittle, block etc?
So the hole is pressure relief?
Dan318-is
They didnt for me; recognised the part numebr i gave an said ye we have them in stock come get it now lolBrianmoooore wrote:So common that they probably won't even need to look up the part number.
Nick45
Doesn't even have to be a BMW part. Standard one from your local neighbourhood spares place will work fine.
Carbs 'n Chrome
kenwoir
SNAP!! I lost pressure in my washers after i had the bonnet off for doing the timing belt and noticed yesterday when i had the bonnet open that when i flicked the washers on it was like a fountain below the bonnet, the 2 t-piece typr connectors, (like little barrells) where pissing water out of 2 wee tiny holes in each. So i'm gathering by what you guys are saying that they are fooked and i need new ones.... Is it just me or does everything just start failing in the winter??
donny1888
had that problem myself a few months ago, found a t piece of an audi seems to do the trick.
amit325i
I found on average the life expectancy of these bits to be a couple of years at the best! I have replaced it 3 times now, its an easy but annoying job! Those clamps are a pain to get of though!
Dan318-is
cable tiesamit325i wrote:I found on average the life expectancy of these bits to be a couple of years at the best! I have replaced it 3 times now, its an easy but annoying job! Those clamps are a pain to get of though!
What are you putting in your washer bottle? They last ten years at least.amit325i wrote:I found on average the life expectancy of these bits to be a couple of years at the best! I have replaced it 3 times now, its an easy but annoying job! Those clamps are a pain to get of though!
ad318i
mines gone and i need 2 get one as well!!!
going home 2morrow might pop over to the local stealer and get sum there
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
