Windscreen washer jet T piece leaks.
tomstickland
Sat Feb 04, 2006 9:53 pm
I've found that the T piece for the windscreen washer jet is pissing water out of two small holes in it. I guess that these are pressure relief holes? Does that mean that the jets are blocked? Or is it a fault?
MONSPORT42
Sat Feb 04, 2006 10:28 pm
Mine's doing the same at the moment. My jets were blocked and I cleared them with a needle this morning but the T piece is still squirting. It happened a few years ago and I replaced all the bits. I think I put in too much screen wash and a crusty residue has built up. I intend to empty the reservoir and wash it all through with warm water and see how it goes
YOUR LEFT FOOT'S FOR BRAKING
Sat Feb 04, 2006 10:34 pm
tomstickland wrote:I've found that the T piece for the windscreen washer jet is pissing water out of two small holes in it. I guess that these are pressure relief holes? Does that mean that the jets are blocked? Or is it a fault?
Common fault. Needs replacing. Not expensive from the dealer.
tomstickland
Sat Feb 04, 2006 11:03 pm
OK, thanks, I'll replace. Meanwhile I'm going to jubilee clip a glove over the holes. I'm fed up with the Grey world I see through the front screen.
jayE30lover
Sun Feb 05, 2006 6:36 pm
just to let you know mate, mine had the same problem, bought new piece from bm and they were litterally pence mate!
318i: kicken Sie ein Esel-Baby!
Dan318-is
Sun Feb 05, 2006 6:45 pm
as brian says common fault; mine failed the other week, my local dealer even had it in stock
was less than four pounds
Sun Feb 05, 2006 10:05 pm
So common that they probably won't even need to look up the part number.
tomstickland
Sun Feb 05, 2006 11:30 pm
Great, thanks for the info.
Why do they fail though? Do they seize up, go brittle, block etc?
So the hole is pressure relief?
Dan318-is
Sun Feb 05, 2006 11:31 pm
Brianmoooore wrote:So common that they probably won't even need to look up the part number.
They didnt for me; recognised the part numebr i gave an said ye we have them in stock come get it now lol
Nick45
Mon Feb 06, 2006 4:44 pm
Doesn't even have to be a BMW part. Standard one from your local neighbourhood spares place will work fine.
Carbs 'n Chrome
kenwoir
Wed Feb 08, 2006 9:04 am
SNAP!! I lost pressure in my washers after i had the bonnet off for doing the timing belt and noticed yesterday when i had the bonnet open that when i flicked the washers on it was like a fountain below the bonnet, the 2 t-piece typr connectors, (like little barrells) where pissing water out of 2 wee tiny holes in each. So i'm gathering by what you guys are saying that they are fooked and i need new ones.... Is it just me or does everything just start failing in the winter??
donny1888
Wed Feb 08, 2006 9:15 am
had that problem myself a few months ago, found a t piece of an audi seems to do the trick.
amit325i
Wed Feb 08, 2006 5:19 pm
I found on average the life expectancy of these bits to be a couple of years at the best! I have replaced it 3 times now, its an easy but annoying job! Those clamps are a pain to get of though!
Dan318-is
Wed Feb 08, 2006 6:42 pm
amit325i wrote:I found on average the life expectancy of these bits to be a couple of years at the best! I have replaced it 3 times now, its an easy but annoying job! Those clamps are a pain to get of though!
cable ties
Wed Feb 08, 2006 8:47 pm
What are you putting in your washer bottle? They last ten years at least.
ad318i
Wed Feb 08, 2006 8:53 pm
mines gone and i need 2 get one as well!!!
going home 2morrow might pop over to the local stealer and get sum there
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
