325i Auto Fuel Consumption - eek!
M3KUK
What should my 325i Auto be doing to the gallon around town?
18MPG?
18MPG?
About 22 MPG is BMW's figure.
M3KUK
Thanks, the big hole in my exhaust probably isn't helping!
M3KUK
Ha Ha! give me a chance, I've only had car a week! Just a bit shocked that my E46 M3 does more to the gallon!
bosers
Yeah they really are shoite on fuel, I was staggered when I worked out the consumption on my first one. Hey, petrol's under a quid a litre now though!
Mr-Lachs
All part of the fun though, I've always said sub 20mpg is a good thing because it means your in an enjoyable car
Ive always (personally) thought looking at mpg took the enjoyment out of it and as such I've never bothered
Hope your getting on ok with the car
Mr-Lachs
1988 BMW E30 325iSE Auto, 4 Door, Lachs Silver (Fair Weather Machine)
2012 Vauxhall Insignia 1.8 Exclusiv, Technical Grey, (The Daily)
bosers
Absolutely agree Mr Lachs, I don't worry about it anymore, it's 'smiles per gallon' . Sorry for awful pun. I just monitor it to make sure it's fairly constant these days
Mr-Lachs
Haha brilliant bosers, smiles per gallon is the way to look t it i agree if it needs it it gets fired in, but yes good to know if its drastically altered for some reason.
Mr-Lachs
One that's working as it should be, engine and suspension, is even more fun, with better MPG as a bonus. One of the problems with E30s is that they tolerate neglect so well, and the deterioration of parts goes largely unnoticed, until you drive one in good condition, and realise what you've been missing.
M3KUK
Just been reading the E30 Wiki and it mentions the OBC can read US and UK Gallons, I'd better check it's reading right.
KW355
I dream of getting 18 mpg
Kos
you get 18mph per secondKW355 wrote:I dream of getting 18 mpg
Mr-Lachs
Are you basing your figure on the OBC? I'd say a more accurate way would be to work it out manually.M3KUK wrote:Just been reading the E30 Wiki and it mentions the OBC can read US and UK Gallons, I'd better check it's reading right.
Mr-Lachs
HairyScreech
Not unusual. up to 34mpg on a run, 24-27 with the mixed shite traffic on the way to work and 15-20 around town.
Not really that unusual. The engines are pretty low compression giving crap efficiency.
bmw9818
cruising at 50-60 back from leicester to london once i only used 1/4 tank literally door to door m1 run then around the m25 to south london and up into croydon,
it was very very heavy rain, so was taking it easy, they can be eco if driven mildly, mines a manual 2.5 though! and engines all been refreshed,
M3KUK
Yes using the OBC, I have fixed my exhaust now so will reset and try again.
OBC goes by what it thinks the injectors are feeding into the engine. If the injectors are old, they are likely to be actually injecting considerably less than this.
