I've looked on realoem but unsure if i need to look at the e36 328i or e30 325i, there is also a large rectangular or triangular plate i don't have either and i'm not sure if it's needed.
Ash
That (excess) white goop will be breaking off on the inside, and gradually collecting in, and blocking, the oil pick up gauze.mark_i wrote: btw the white goop on your sump gasket isn't the best stuff to use...
It's being redone, the white goop is genuine VW stuff. What would people suggest that's better?Brianmoooore wrote:That (excess) white goop will be breaking off on the inside, and gradually collecting in, and blocking, the oil pick up gauze.mark_i wrote: btw the white goop on your sump gasket isn't the best stuff to use...
Which bolts are these?Supafly wrote:I would also change the long bolts which will be tight against the flywheel to hex bolts as removing them later on will be a pain if there isn't enough clearance.
Do you mean that the underside of the heads of the bolts are only about 5mm from the face of the 'plate' before the bolts enter the threads in the crank, and then only turn three turns before they go tight?ashje wrote:Okay i've gone to tighten up the flywheel and the bolts will go 3 turns before going tight, is this correct?
That's exactly what i mean, i thought it wasn't correct so did not torque anything up. It was getting dark this evening so i will have a proper look tomorrow and report back.Brianmoooore wrote:Do you mean that the underside of the heads of the bolts are only about 5mm from the face of the 'plate' before the bolts enter the threads in the crank, and then only turn three turns before they go tight?ashje wrote:Okay i've gone to tighten up the flywheel and the bolts will go 3 turns before going tight, is this correct?
If so, this is NOT correct, and you are likely to fatally damage the crank if you torque it up, plus you will likely end up minus a pair of legs if you drive the car with this fitted.
If you've used M20 bolts and flywheel, I've no idea what is wrong, unless it's simply that the flywheel isn't seated on the crank, but something definitely is!
As a general rule, the minimum any bolt that's running anywhere near its maximum torque, should engage with a nut a minimum of the diameter of the bolt.
28mm is the correct length?willnz wrote:Your bolts are too short, end of..
