Can't seem to find much advice on here about the m54b30 engine. I currently have a full 330 car and engine which I'm breaking.
As I'm looking for another e30 or e21, I was wondering what's the adivicr on fitting this into an e30. I can't seem to find a section or on search but I've seen it been done.
I am contemplating keeping it to fit, if it's reasonable as its a solid engine. Low miles. New belts etc.
M54B30 advice
Not many people in the UK fit the M54B30, main reasons are they usually demand more money to buy and the power is only as good as a M52B28 with M50 intake manifold and map.
I'm halfway through converting an E30 at the moment with one of these engines
Tewkes
How much is the b28 engine though?
What about electrics, mounting and rad etc?
You can pick up a 2.8 for £200-£300
Electrics are more tricky, but I've pretty much got it sorted now
Tewkes
Tricky in what sense?
Can't find much info online. Sorry for the questions.
Tewkes
I understand.
Isit a normal mapping company that's able to code out a lot of the features or isit more specialised than that?
HairyScreech
You can run the M54 on the OBD1 management using the DISA and twin vanos controller made buy a guy in the states.
Think the Siemens M52 ECU etc can be used as well but tuning is tougher in the UK as less support.
Tewkes
How much is that unit made on the states?
reggid
The guy from Racehead.com.au has a couple M54B30's running on EMU (economical standalone) with vanos control and good results etc.
E30 325is with M20B31
Tewkes
I'm so confused here with all these different methods to running the engine haha. It's a pretty tough subject as not many have done it.
ajay
Getting your M54B30 running is pretty much the same as an S54, and there are plenty of them running in E30's in various different forms, have a chat with Ergen motorsport (Adem) i'm sure he can supply you a modified plug & play kit that includes flashing your ecu, its not the way i'm doing mine ( standard ecu) but probably your best bet if you have no wiring experience.
Tewkes
I'll be sure to give him a ring.
