Taking apart tail lights
Sambe30
Can you take apart tail lights to get to just the lenses? I have them out but still have the black plastic on the back, i need to take some film off that is on the inside but can't work out how to get to the back of the lense
HairyScreech
You sure its film and not tint spray sprayed through the bulb hole?
Sambe30
If it is spray through the bulb hole it's a very neat job as there is none on anything else! Is there away of taking the black plastic part off? Only reason I ask is that they are genuine mhw lights
steve_k
if they are genuine MHW then are they smoked or all red? if it's either then you wont be able to remove any tint be it film or spray.Sambe30 wrote:If it is spray through the bulb hole it's a very neat job as there is none on anything else! Is there away of taking the black plastic part off? Only reason I ask is that they are genuine mhw lights
Sambe30
steve_k
if it's on the outside (which it should be, run your finger over it & if you can feel it then it's on the outside) then try some watered down paintstripper or nail varnish remover.
Sambe30
It's on the inside, not the outside
steve_k
watered down paint stripper on the inside sloshed about then rinsed out (several times) with warm soapy water, see if that helps.Sambe30 wrote:It's on the inside, not the outside
Sambe30
Ok will try that tomorow, so the is no way of getting the black part away from the lense?
steve_k
not as i know of, don't want to wreck an expensive set of lenses.Sambe30 wrote:Ok will try that tomorow, so the is no way of getting the black part away from the lense?
Sambe30
Yeah, I will try water down paint stripper tomorow and let you know
steve_k
no worries, just make sure it's thinned right down to avoid any damage.Sambe30 wrote:Yeah, I will try water down paint stripper tomorow and let you know
Jesus325iTouring
- Frog freak !
I would try the yellow Craftsman Nitromors, much thinner than regular green multi purpose Nitromors, I used it the other day on some fine finish work tops and its effective but not nearly as aggressive. Green will burn your skin, yellow doesn't
Kedge
I'd be trying bodyshop paint thinners before anything like Nitromors.
TriggerFish
A word of warning, and it might not apply here, but be careful of the silver finish! I managed to take a load off of the rear lights on my 330d when trying to get a dead fly out of the cluster, and that was only using my finger. I don't know how the E30 lights would react to a solvent.
(I might be talking crap, but better safe than sorry?)
HairyScreech
I would be trying detol before anything else.
Detol contains pine oil. It can take acrylic paint off if left to soak.
Very unlikely to damage the tail light plastic as well.
However what ever you use, brush some onto a hidden area/the side of the lights and leave it to see if it damages the paint. Detol/pine oil I would leave over night at least.
I have left styrene based plastics in it until the detol had dried up and they did not melt but it did slightly soften/etch the surface after that length of time.
I would be selling them (along with that offensive exhaust) to a council type and buying some nice originals. Just like the ones I have available
sweep
Iirc these dont have reflectors in them
andyp
- True Old Skooler
he is coming to set a nice set the weekendpacerpete wrote:I would be selling them (along with that offensive exhaust) to a council type and buying some nice originals. Just like the ones I have available
Sambe30
Pete Andy has me covered on lights! And will try detol tonight, and the reason I'm cleaning the paint off is to sell!
andyp wrote:he is coming to set a nice set the weekendpacerpete wrote:I would be selling them (along with that offensive exhaust) to a council type and buying some nice originals. Just like the ones I have available
Good man
