Taking apart tail lights
Sambe30
Wed Oct 28, 2015 4:11 pm
Can you take apart tail lights to get to just the lenses? I have them out but still have the black plastic on the back, i need to take some film off that is on the inside but can't work out how to get to the back of the lense
HairyScreech
Wed Oct 28, 2015 6:07 pm
You sure its film and not tint spray sprayed through the bulb hole?
Sambe30
Wed Oct 28, 2015 7:51 pm
If it is spray through the bulb hole it's a very neat job as there is none on anything else! Is there away of taking the black plastic part off? Only reason I ask is that they are genuine mhw lights
steve_k
Wed Oct 28, 2015 7:54 pm
Sambe30 wrote:If it is spray through the bulb hole it's a very neat job as there is none on anything else! Is there away of taking the black plastic part off? Only reason I ask is that they are genuine mhw lights
if they are genuine MHW then are they smoked or all red? if it's either then you wont be able to remove any tint be it film or spray.
Sambe30
Wed Oct 28, 2015 8:07 pm
Just had another look, they are mhw but some idiot has painted only the r/h side light fog light part red and not the left, you can see one drip in the paint, how would I get this apart to get the paint off, see pic below right side light
steve_k
Wed Oct 28, 2015 8:13 pm
Sambe30 wrote:Just had another look, they are mhw but some idiot has painted only the r/h side light fog light part red and not the left, you can see one drip in the paint, how would I get this apart to get the paint off, see pic below right side light
if it's on the outside (which it should be, run your finger over it & if you can feel it then it's on the outside) then try some watered down paintstripper or nail varnish remover.
Sambe30
Wed Oct 28, 2015 8:15 pm
It's on the inside, not the outside
steve_k
Wed Oct 28, 2015 8:19 pm
Sambe30 wrote:It's on the inside, not the outside
watered down paint stripper on the inside sloshed about then rinsed out (several times) with warm soapy water, see if that helps.
Sambe30
Wed Oct 28, 2015 8:24 pm
Ok will try that tomorow, so the is no way of getting the black part away from the lense?
steve_k
Wed Oct 28, 2015 8:26 pm
Sambe30 wrote:Ok will try that tomorow, so the is no way of getting the black part away from the lense?
not as i know of, don't want to wreck an expensive set of lenses.
Sambe30
Wed Oct 28, 2015 8:44 pm
Yeah, I will try water down paint stripper tomorow and let you know :D
steve_k
Wed Oct 28, 2015 9:39 pm
Sambe30 wrote:Yeah, I will try water down paint stripper tomorow and let you know :D
no worries, just make sure it's thinned right down to avoid any damage.
Jesus325iTouring
Frog freak !
Frog freak !
Wed Oct 28, 2015 11:32 pm
I would try the yellow Craftsman Nitromors, much thinner than regular green multi purpose Nitromors, I used it the other day on some fine finish work tops and its effective but not nearly as aggressive. Green will burn your skin, yellow doesn't :D
Kedge
Thu Oct 29, 2015 11:51 am
I'd be trying bodyshop paint thinners before anything like Nitromors.
Instagram - Kedge85
TriggerFish
Thu Oct 29, 2015 12:23 pm
A word of warning, and it might not apply here, but be careful of the silver finish! I managed to take a load off of the rear lights on my 330d when trying to get a dead fly out of the cluster, and that was only using my finger. I don't know how the E30 lights would react to a solvent.
(I might be talking crap, but better safe than sorry?)
HairyScreech
Thu Oct 29, 2015 4:57 pm
I would be trying detol before anything else.
Detol contains pine oil. It can take acrylic paint off if left to soak.
Very unlikely to damage the tail light plastic as well.
However what ever you use, brush some onto a hidden area/the side of the lights and leave it to see if it damages the paint. Detol/pine oil I would leave over night at least.
I have left styrene based plastics in it until the detol had dried up and they did not melt but it did slightly soften/etch the surface after that length of time.
Thu Oct 29, 2015 5:35 pm
I would be selling them (along with that offensive exhaust) to a council type and buying some nice originals. Just like the ones I have available :)
sweep
Thu Oct 29, 2015 6:05 pm
Iirc these dont have reflectors in them :(
andyp
True Old Skooler
Thu Oct 29, 2015 7:46 pm
pacerpete wrote:I would be selling them (along with that offensive exhaust) to a council type and buying some nice originals. Just like the ones I have available :)
he is coming to set a nice set the weekend
Sambe30
Thu Oct 29, 2015 7:54 pm
Pete Andy has me covered on lights! And will try detol tonight, and the reason I'm cleaning the paint off is to sell!
Thu Oct 29, 2015 11:15 pm
Good man :)
