How do you open the boot with
Out any keys....
Open boot with out keys..
Buy a key from BMW.
BHadley
Can you get in the car any other way? What is it cab saloon touring?
HairyScreech
If its a normal E30 then you can probably put your arm through the rust hole in the inner arches to get into the boot.
Unless the boot lock is in the horizontal, fully to the right, position, where it can only have been put with a key, the boot should be able to be opened by simply pushing the button after operating the central locking.
Can we have the full story behind this, please?
pukar
Driverstu325
The cab is my own car....
The boot lock problem is I found a e30
In scrap yard but the boot is locked.they
Brought it from auction with no keys
The car it self is open but wanted to see
If there was any gudys in the boot...
like the boot cover..
IF the car is a saloon, remove the rear seat cushions and you will find an almost cut out 'ski hatch' blanking panel in the middle of the seat back.
Use a small chisel and hammer to cut through the small remaining pieces of metal, remove the panel, and then you will be faced with rear section of the boot liner.
Pushing on this will push it off its fixing clips, and then you will be able to see into the boot.
If you still need to open the boot, push a child through the hole, armed with a 10mm spanner, and refuse to let him back out until he has unscrewed the bolts holding the lock.
BenHar
I think that this car is a cabriolet.
Probably the easiest way is to break a rear light.
Pleanty of spares available from the wanted section on here.
Ben
Ben
