C405 pins
alexm3uk
Post Wed Oct 14, 2015 5:39 pm
Does anyone have a uk source for these pins as I need to rewire
BMW want almost £1 a pin I need 20 male and 20 female a˜”
I did look on zone wiki but it's in Poland and they don't have stock on the female pins
Help please
alexm3uk
Post Wed Oct 14, 2015 7:32 pm
Let's hope so a˜„a˜„
alexm3uk
Post Wed Oct 14, 2015 8:42 pm
alexm3uk
Post Thu Oct 15, 2015 10:39 pm
Anyone know if these will work ?
Post Fri Oct 16, 2015 1:34 pm
They look correct, I've always been able to reuse the pins when messing with the door plugs, best way to be sure is to remove a pin and measure it
Post Fri Oct 16, 2015 2:52 pm
They are readily available 'standard' pins, but whether they are the ones you've found, I couldn't say.
I'm also too tight to use new, and reuse the pins, the same as Dan, or extract a suitable one from a scrap loom.
alexm3uk
Post Fri Oct 16, 2015 5:47 pm
Lol ok I will order a bag of each through work that way I'm not pay either a˜€a˜€a˜€a˜€
alexm3uk
Post Fri Oct 16, 2015 6:17 pm
No do you need a special tool ? If so please link it for me
Was just to use a very small screwdriver
bimanut
Post Fri Oct 16, 2015 6:32 pm
I'd be interested in a tool for the job aswell as they are right pita to get out!
alexm3uk
Post Fri Oct 16, 2015 6:42 pm
cheers mate :D :D :D
bimanut
Post Fri Oct 16, 2015 6:43 pm
