Broken Key
Alright. I have a 1987 325is I broke the key in the door while trying to unlock the driver side door. It's stuck in there pretty deep and in horizontal position. I've tried pulling up on the locks with a cable but they don't want to come up at all. That was my only key so I can't unlock anything to get in my car. Is there a way to get in the car or extract the key or something. The trunk and both doors are locked but I can get into the engine bay.
- Brianmoooore
brutus wrote:yep, back ones are cheaper if it all goes wrong !
Maybe, but I've yet to work out how to disconnect the demister element plugs from the outside. Front screen is easy to remove and replace with a bit of care.
If the key that you broke worked in the ignition and all the locks, it was probably the original, so investing around £20 with BMW for a shiny new torch key is probably the best solution.
You still won't get into the car if the deadlocks are set, but you will be able to get into the boot, be able to remove the ski hatch blanking plate, and get into the cabin that way if you are slim, or use a small child to wind down a window.
Well. I extracted the broken key by removing the silver dust cover and taking a scroll saw blade. It was very quick and caused me no problems. You just slide the blade all the way in turn it some to apply pressure from the teeth to the key and pull out and it comes right out. Also I'm located in Texas, USA My local bmw dealership is asking around $90 dollars for a new key for that car and it would take a week to get in. So I'm trying to stay away from that idea
