Started of with a fried ECU, so had a good friend deliver one from his project cars as he is running mega squirt... Drove it to scrutinering, couldn't drive away from there. Good start...
The car handles perfect, even though its running with a welded diff. I have bought an LSD but need to figure out how to bring ring gear closer to the pinion gear. The LSD is from a 2.65 diff and I'm running a 4.10. Anyway not a hint of understeer. Just send it in!
Here is the issues I need to fix:
-Fuel surge on right hand corner. As I can figure out and find on the internet, it’s because of the transferring of fuel from left to right side of the tank(63L) is not working, bad fuel pump etc. If anybody have ideas of a good setup with standard parts and not a fuel cell setup, I'm all ears! It has to pass an MOT and fuel cells are not approved in DK...
-New generator as the its only charging with 11-12V.
-To noisy(I don't see a problem in that. 106dB at driveby....)
-Electrics played up a bit, but I did a full rewire so did expect that to play up a little.
-Brakes starts to get very spongy after 15-20min of driving. I had the brakesystem fully apart, so might just need to be bleed again.
-Hand brake is dragging a bit. I installed a completly new handbrake system as it was taken away(old rally car).
Its not to bad really, most of the fixes are easy to sort out. My biggest worry is the fuel surge!
Spec of the car:
E30 325I
M50B25TU engine with different cams (don't know which).
It hits the limiter at 7000 and has been dynoed to 205bhp..
BC racing suspension, which is quite nice!
4.10 welded did. Which to my surprise didn't make it a bitch to drive!
Toyo 888 tyres - 225/45/15
Standard brakes with EBC yellow pads. Might make some cooling for them.
The car will be used for hill climbs which means it has to pass an MOT and they are like the german SS here in Denmark! Just about got it through. Some MOT places will hit at the same place with their little hammer until there is a hole and say: you got a rust problem! Also, hill climbs are short, only 2-3 miles at a time. So it’s not going to be any heat problems...
So all-good fun to drive. Fast as well
