Well, my 6yr restoration thread buggered by photobucket
jimf
Post Sun Jun 28, 2015 8:26 pm
ALARM REMOVAL CONTINUED & OBC RETROFIT June 2015
It's all coming together now, the car is still starting fine and things are looking much neater. I've even managed to tidy up all the stereo wiring, fit my 13 button OBC and replace the heater panel bulbs. Obviously still need to fit the temp sensor but that is on it's way.
BHadley
Post Sun Jun 28, 2015 11:22 pm
Takes me back to the late 90s when these where everywhere and in top nick!
Almost convinced the old man to buy one......
Anyway, nice job.....
jimf
Post Mon Jun 29, 2015 12:10 am
Thank you, if only we could go back in time and invest in one for a decent price and keep it nice. Instead I choose to take this one that has been abused, badly repaired and messed about with and make the best of it within my ability. It's either this or I spend every penny I have on a mint one, but I need to eat and pay the mortgage.
Sanchez
Post Mon Jun 29, 2015 1:05 am
All good fun keeping them going.
Keep up the high standards.
Gert_8
Post Mon Jun 29, 2015 9:41 am
This is turning into an extremely nice car! I can't believe the amount of wiring that has been removed from it..! 8O
If that temp is correct, it's a bit damned cold where you are! :D
jimf
Post Mon Jun 29, 2015 10:31 am
I am in North Scotland right enough but I have the temp sensor on the way so will be a more accurate reading next week. Double figures would be nice!
jimf
Post Sat Jul 04, 2015 10:04 pm
WIRING COMPLETE June 2015
The loom is pretty much back to factory spec now after removing 4kg of after market wiring!
jimf
Post Sat Jul 04, 2015 10:48 pm
UNDERTRAY, WHEELARCH LINERS & DUCTING June 2015
The car has always looked a bit odd without the wheelarch trim and ducting so I sourced everything second hand and it all looks a bit more complete and less flimsy now
jimf
Post Sat Jul 04, 2015 11:21 pm
E36 SPORT SEAT & REAR HEADREST UPGRADE July 2015
A while ago I bought an E36 328i Coupe breaker so I could fit the engine to my E34. I kept the seats and always thought they would be good in my E30. I'm 6'2" and always found the E30 seats a bit small for my height. I stripped them down, re-dyed them to match the Cardinal Red then designed some brackets and had them locally manufactured. Now they are fitted I can say they are much more comfortable and feel a lot more robust than the creaky old E30 seats. They were a very tight squeeze and it was a lot of work getting them into place but they don't look too out of place in the E30. I also bought some rear headrest brackets and used the front E30 headrests.
jimf
Post Sat Jul 04, 2015 11:41 pm
CONTROVERSIAL ///M BADGE July 2015
I'm not explaining myself, I just like it
MPOWERCRAZY
Post Sun Jul 05, 2015 10:30 am
Them seats come out excellent mate, I've always wanted to dye my seats to give them that fresh look, lovely colour and good thinking :)
Back Again From The Darkside Of Doing E36'S :mad:
Back With 2 E30 Projects :cool:
daboy3000
Post Thu Jul 16, 2015 10:51 pm
Amazing work.
baggimodo
Post Fri Jul 17, 2015 8:25 am
Seats look superb mate, certainly a lot more to them than the e30 versions though at my height the standard sports are pretty comfortable!
Sonatine
Post Fri Jul 17, 2015 6:21 pm
Jim, was the heater panel bulb out or low?
Andyboy
Alpina Colada
Post Fri Jul 17, 2015 9:39 pm
Some epic work there - those seats are superb. Well done!
jimf
Post Fri Jul 24, 2015 10:03 am
Sonatine wrote:Jim, was the heater panel bulb out or low?
The bulb had blown
Sonatine
Post Sat Jul 25, 2015 4:55 pm
Not driven my car in the dark yet but the cluster and dash lights don't seem very bright at all. I have adjusted the knob.
ianev
Post Sat Jul 25, 2015 8:40 pm
Good works JimF - may I ask where you acquired the undertray from and how difficult it was to fit - did you have all the clips etc with the replacement?
Thanks.
jimf
Post Wed Jul 29, 2015 6:59 pm
Sonatine wrote:Not driven my car in the dark yet but the cluster and dash lights don't seem very bright at all. I have adjusted the knob.
Remember the bulbs in your car are likely to be 25 years old, my dash is dull too and all could do with being replaced.
jimf
Post Wed Jul 29, 2015 7:00 pm
ianev wrote:Good works JimF - may I ask where you acquired the undertray from and how difficult it was to fit - did you have all the clips etc with the replacement?
Thanks.
The undertray was from a breaker, it was ok to fit but I have had to use a couple of zip ties to make sure it is secure.
jimf
Post Thu Apr 13, 2017 8:54 pm
BASIC SERVICING WENT WRONG
A long overdue update, last year I started a servicing with the intention of changing the timing belt, water pump, cam seal, distributer cap etc. Whilst I had all the covers off I started cleaning everything up and decided to take the thermostat housing completely off as it looked very tatty. Well after thirty years on the car it was not for budging and after a while........I snapped the studs flush with the cylinder head!!!!!
After half a day drilling I eventually ended up snapping two stud extractors in the studs. I had to bute the bullet and take the head off and take it to a machine shop.
jimf
Post Fri Jul 14, 2017 4:36 pm
Thanks a bunch photobucket you bastards. End of thread for now
cornershop
Post Sun Jan 21, 2018 9:33 pm
Try this if you use Google Chrome - works for me and i can see all your pics :)
"If you're using Google Chrome, go to the three dots on the top right side of the screen and click them. A drop down should appear. Hover your mouse over "More Tools," and when the next drop down appears, click on extensions. Go to the link towards the bottom that says "Get more extensions." In the search box, type "Photobucket Fix," and hit enter. Click the install button and once it's done, you should be able to see photobucket pictures again"[/b]
Post Mon Jan 22, 2018 12:45 am
cornershop wrote:Try this if you use Google Chrome - works for me and i can see all your pics :)
He's right!
paultv
Post Mon Jan 22, 2018 7:55 am
works for me too!
Steve
Post Mon Jan 22, 2018 9:38 am
Nice temp fix Cornershop, thanks for sharing :thumb:
I'll make a sticky post :D
webmaster@e30zone.net
Post Mon Jan 22, 2018 10:10 am
fantastic , that's me sorted thank you .
BenHar
Post Mon Jan 22, 2018 11:43 am
This add-on fixes it in Firefox:
https://addons.mozilla.org/en-US/firefo ... x/?src=api
Ben
Yeti
Post Tue Jan 23, 2018 2:01 pm
mate life saver
Post Fri Nov 16, 2018 6:26 pm
No add ons in my browser and all the old pics are now showing :D
Steve
Post Fri Nov 16, 2018 6:33 pm
Yeah I think Photobucket has had a rethink :D
Steve
Post Thu Nov 22, 2018 9:01 am
Get those photos backed up and added to the Zone before photobucket goes again !
