M52 b30 stroker rebuild back on the road
hotross
Post Thu May 14, 2015 10:06 pm
12 thou is like the max. With a standard gasket it must of been close as...
Which gasket you using this time around with the M52b30?
Post Fri May 22, 2015 7:48 pm
progress report >>>>>>>>>>>
an hour in the morning will see it ready for the mot once the bonnet is on and the panel gaps lined up ....... lovin the bullseyes 8)
got the "Ernst" back box fitted and it's very quiet campared to the scorpion ..... need to drive it first before i decide if it's staying .... no "Whafting" along here !
i need a double fog light swith of all things ..... can't find mine anywhere and i don't have any spare :( , i've got a single foggy switch so at least i can get the rears working for mot time .
Post Sat May 23, 2015 6:15 pm
she goes rather well :D
[youtube][/youtube]
jmc330i
Post Sat May 23, 2015 6:47 pm
Nice :cool:
James
'91 325i Sport
'93 318i touring 16v
sweep
Post Sat May 23, 2015 6:49 pm
Very good mick
Post Sat May 23, 2015 8:23 pm
cheers lads , got round to some bufty action today >>>>
cleaned all the grime off and fitted the new insulation , great improvement :D
also managed to squeeze in some councilness
///M-TECH innit :D
Post Mon May 25, 2015 5:10 pm
taxed, tested and covered 90 miles no problem , :D
jimbom30cab
Tech 1 freak
Post Mon May 25, 2015 5:23 pm
Awesome, give us the full low down on how the 3 litre feels over a 2.8 then
jmc330i
Post Mon May 25, 2015 5:25 pm
Looks good 8) and after all the work a new MOT is a great feeling :D
Seeing yours makes me want to keep my RG wheels, but I've just bought 2 new 15" tyres for MOT :roll:
Id also be interested to hear the difference of the 3.0 over the 2.8 :D
James
'91 325i Sport
Post Mon May 25, 2015 6:23 pm
1st gear just wants to spin with hardly any effort and a bit embarrasing when i don't want to do it lol ...... 3rd gear pull is great i don't need to thrash the bores out of it now. The extra torque is just what the m52 needed , i found myself kicking the clutch to get the revs up into vanos quicker when it was a 2.8 .
95 mph at 3k revs :bmw:
Post Fri May 29, 2015 8:51 pm
Looking good Mick :cool:
appletree
Post Fri May 29, 2015 9:50 pm
What flavour diff you running?
Posted your tree out today, was away with work, sorry
Post Fri May 29, 2015 11:11 pm
3.07 torsen ....
Post Fri May 29, 2015 11:23 pm
i could be out by 5-7 mph with th 16's
appletree
Post Sat May 30, 2015 6:49 am
magpie wrote:3.07 torsen ....
Same as me, nice to have 6th as an overdrive gear isn't it :D
Post Sat May 30, 2015 10:43 am
yeah it's great , i kept going for 6th gear when it was a 5 speed :mad:
Post Sat May 30, 2015 11:46 am
all my gears are fine but when on tick over the box is noisey unless i hold the clutch down ...pretty p1ssed off about this but not gonna let it spoil the moment as it works ok apart from this .
looks like i've been tucked up again, that's every gearbox i've had in the car now :roll:
anyhoo i've bought some better g/box gloup that might shut the box up a bit and my engine oil and filter turned up ...
BenHar
Post Sat May 30, 2015 12:06 pm
magpie wrote:all my gears are fine but when on tick over the box is noisey unless i hold the clutch down ...
Might be the release bearing, Mick.
Ben
Post Sat May 30, 2015 12:14 pm
Ben
brand new clutch and bearing mate .
appletree
Post Sat May 30, 2015 11:23 pm
Could be wrong Mick but think there's 3 different types of oil for the 6 speeders depending on what colour sticker your box has known it, think there was a green, orange and yellow sticker. Don't know why there would be a difference but sure when I looked into it there was.
BenHar
Post Sun May 31, 2015 10:44 am
Ben
How about the spigot bearing? Definitely the right size?
Ben
appletree
Post Sun May 31, 2015 11:43 am
BenHar wrote:
magpie wrote:
BenHar wrote: Might be the release bearing, Mick.
Ben
Ben
Good point my standard IS one was the wrong size for the 6speeder had to get another off a beating company.
rotta
Post Sun May 31, 2015 1:15 pm
is it flywheel chatter? or maybe the lay shaft bearing is failing?
jimbom30cab
Tech 1 freak
Post Mon Jun 01, 2015 8:24 am
Mick, my 6 speed is the same, with the clutch up and in neutral it does clatter a bit.
I was worried about it , did a load of googling and it seemed a common thing.
It's not got any worse a year later on.
I used Royal Purple syncromax oil for your info.
Post Mon Jun 01, 2015 8:52 am
Its a Getrag thing :D
Post Fri Jul 03, 2015 9:23 am
will any other 6- speed boxes fit i.e e46 one ??
i've got a zf 5-speed here but need a prop coz i cut mine up to fit the 6-speed :roll:
Post Sat Jul 04, 2015 10:07 am
managed to locate a prop £75 delivered ... my eyes have been pulled out again :cry:
on a brighter note every coont else wants £99.99 + courier .
i'm not giving up on the 6-speed just yet ..... reconditioned might be an option .
Post Sat Jul 04, 2015 6:15 pm
Id get it rebuilt Mick, will probably be cheaper than buying another worn box
hennared323i
Post Sat Jul 04, 2015 6:24 pm
wcpgw?
Post Sun Jul 05, 2015 7:10 pm
hennared323i wrote:wcpgw?
pardon ?
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun Jul 05, 2015 7:22 pm
What could possibly go wrong :wink:
Post Sun Jul 05, 2015 7:50 pm
it's already gone wrong .... a gearbox repair isn't going to be cheap and i'll probably have to pull the engine out to remove the box .
Post Sun Jul 05, 2015 7:55 pm
My 6 speed box in my e36 has been noisey on idle for 40,000 miles like every other getrag box. Sound no worse than any M20 box i've had. I'd not worry too much
Andyboy
Alpina Colada
Post Sun Jul 05, 2015 9:04 pm
The rattle at idle is the lay gear having a bit too much play/backlash. I wouldn't worry about it. If it bothers you that much drain it and bang some EP90 in there - not even remotely recommended by the manufacturer but it'll quieten it down. I did this on a five speed E46 unit and it's still going now and the gearshift is fine - a bit baulky in very cold weather.
Post Sun Jul 05, 2015 9:14 pm
Was a handful of sawdust that did the trick in my day.
