M52 b30 stroker rebuild back on the road
progress report >>>>>>>>>>>
an hour in the morning will see it ready for the mot once the bonnet is on and the panel gaps lined up ....... lovin the bullseyes
got the "Ernst" back box fitted and it's very quiet campared to the scorpion ..... need to drive it first before i decide if it's staying .... no "Whafting" along here !
i need a double fog light swith of all things ..... can't find mine anywhere and i don't have any spare
, i've got a single foggy switch so at least i can get the rears working for mot time .
+ a yard full of scrap turds
cheers lads , got round to some bufty action today >>>>
cleaned all the grime off and fitted the new insulation , great improvement
also managed to squeeze in some councilness
///M-TECH innit
///M-TECH innit
jimbom30cab
- Tech 1 freak
Awesome, give us the full low down on how the 3 litre feels over a 2.8 then
Looks good
and after all the work a new MOT is a great feeling
Seeing yours makes me want to keep my RG wheels, but I've just bought 2 new 15" tyres for MOT
Id also be interested to hear the difference of the 3.0 over the 2.8
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
1st gear just wants to spin with hardly any effort and a bit embarrasing when i don't want to do it lol ...... 3rd gear pull is great i don't need to thrash the bores out of it now. The extra torque is just what the m52 needed , i found myself kicking the clutch to get the revs up into vanos quicker when it was a 2.8 .
95 mph at 3k revs
95 mph at 3k revs
What flavour diff you running?magpie wrote:
95 mph at 3k revs
Posted your tree out today, was away with work, sorry
appletree wrote:Same as me, nice to have 6th as an overdrive gear isn't itmagpie wrote:3.07 torsen ....
yeah it's great , i kept going for 6th gear when it was a 5 speed
all my gears are fine but when on tick over the box is noisey unless i hold the clutch down ...pretty p1ssed off about this but not gonna let it spoil the moment as it works ok apart from this .
looks like i've been tucked up again, that's every gearbox i've had in the car now
anyhoo i've bought some better g/box gloup that might shut the box up a bit and my engine oil and filter turned up ...
brand new clutch and bearing mate .BenHar wrote:Might be the release bearing, Mick.magpie wrote:all my gears are fine but when on tick over the box is noisey unless i hold the clutch down ...
Ben
Could be wrong Mick but think there's 3 different types of oil for the 6 speeders depending on what colour sticker your box has known it, think there was a green, orange and yellow sticker. Don't know why there would be a difference but sure when I looked into it there was.
How about the spigot bearing? Definitely the right size?magpie wrote:brand new clutch and bearing mate .BenHar wrote:Might be the release bearing, Mick.magpie wrote:all my gears are fine but when on tick over the box is noisey unless i hold the clutch down ...
Ben
Ben
Good point my standard IS one was the wrong size for the 6speeder had to get another off a beating company.BenHar wrote:How about the spigot bearing? Definitely the right size?magpie wrote:brand new clutch and bearing mate .BenHar wrote: Might be the release bearing, Mick.
Ben
Ben
jimbom30cab
- Tech 1 freak
Mick, my 6 speed is the same, with the clutch up and in neutral it does clatter a bit.
I was worried about it , did a load of googling and it seemed a common thing.
It's not got any worse a year later on.
I used Royal Purple syncromax oil for your info.
will any other 6- speed boxes fit i.e e46 one ??
i've got a zf 5-speed here but need a prop coz i cut mine up to fit the 6-speed
managed to locate a prop £75 delivered ... my eyes have been pulled out again
on a brighter note every coont else wants £99.99 + courier .
i'm not giving up on the 6-speed just yet ..... reconditioned might be an option .
Jesus325iTouring
- Frog freak !
What could possibly go wrong
it's already gone wrong .... a gearbox repair isn't going to be cheap and i'll probably have to pull the engine out to remove the box .
The rattle at idle is the lay gear having a bit too much play/backlash. I wouldn't worry about it. If it bothers you that much drain it and bang some EP90 in there - not even remotely recommended by the manufacturer but it'll quieten it down. I did this on a five speed E46 unit and it's still going now and the gearshift is fine - a bit baulky in very cold weather.
- Brianmoooore
Was a handful of sawdust that did the trick in my day.
