cooling fan advice m52 conversion
matt86
Post Fri May 15, 2015 11:25 pm
Hi,
I was wondering if its best to use the viscous fan on the m52 with e36 air con radiator, or if it would be better to use another fan?
Matt
jmc330i
Post Fri May 15, 2015 11:49 pm
The viscous fan won't fit between engine and rad. You will need an electric pusher fan mounted in front of the rad.
James
'91 325i Sport
'93 318i touring 16v
matt86
Post Sat May 16, 2015 7:58 am
jmc330i wrote:The viscous fan won't fit between engine and rad. You will need an electric pusher fan mounted in front of the rad.
Cheers James I thought this might be the case, do you have any advice on a make/model and what size it should be?
jmc330i
Post Sat May 16, 2015 9:59 am
I used a SPAL 14" pusher fan on my S50 conversion, but I think people have said a 16" fan will just fit. I never had any issues with the 14" and it ran through a very hot summer.
James
'91 325i Sport
